Question about Nikon D90 Digital Camera with 18-105mm lens
My D90 sometimes has an err message and also a CHA in the the ISO mode. Also there is a green LED on the back of the camera that stays on. The only way to get all this cleared is a battery pull. When this happens it wont take a picture, you cant access the menu or anything.
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
CHA indicates a problem with the SD card. ERR indicates a camera malfunction. Try reformatting the card which may clear the problem or try a different card. The card may be creating the ERR message. On page 259 of the D-90 users manual, Nikon says this error can be cleared by releasing the shutter but the shutter will not release unless you turn the camera off and back on. Rarely, I have to remove the battery and reinstall it before the shutter will release. The camera will not function at all until the battery is reinstalled.
If you cannot resolve this problem using the above suggestions, I'd recommend that you contact Nikon technical support at www.nikon.com and see if they can help.
Posted on Jul 14, 2014
makka08
  • 7 Answers
SOURCE: Nikon D80 flashing 'err' and 'off'
Usually you get this kind of problem in variations of temperature. Humidity means moisture and that isn't good. The Nikon D80 body was not built for harsh conditions. Nikon define that any use above 85% humidity, or use near 100 degrees, plus any use involving moisture of any kind? including hands/body (camera resting on a shirt while walking) is bad. So it's not robust by any stretch of the imagination. The model is not made with environmental seals, like pro models. I guess they aimed this model at enthusiastic amateurs and didn't see the need. Trouble is this model can, in the right hands take pro-quality shots. I use two, like you, but I saw this problem coming and I never wear them suspended from the neck and put them away when they are not in use with plenty of silica gel in my bag. I shoot racing and I REALLY sweat! If you have the lcd screen up against you on a hot day it intensifies the heat. The problem is likely to be moisture on the PCB board, which causes corrosion to the board. If you've ever done gym class and the windows have steamed up it's the same thing. It's just means the temperature inside the camera is way too hot. Anything electrical causes heat, so the temperature on the inside is gonna be way hotter. If it is cooler on the outside it causes condensation. If you have dried it out and you still have problems it's gonna need fixing at Nikon. The bottom line is that it's fragile; that is alluded to in the manual. It sounds improbable but I can assure you that Nikon will tell you the same. It's not the sweat on your hands that is causing the moisture..highly unlikely. Hope that helps.
Posted on Sep 26, 2008
SOURCE: "CHA" message - will not take picture
believe it is the film card. Try a different one.
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: nikon d90 - can't take the picture
You just found the Nikon D90 F-- error message solution!
I had the same problem with the Nikon d90 F-- error message which drove me nuts!
I called Nikon, they walked me through a lengthy reset procedure which didn't work. After spending a few hours researching online, I found the answer.
It is not the memory card or nor a defective camera body. The lens does not need to be rechipped.
The F-- error means the camera is unable to communicate with the lens and is caused by a poor connection between the ground contact pin on the lens and the metal mounting ring on the camera. Most people buy the camera, install the lens once and then encounter the error. This one time lens installaiton does not give the contact point a chance to seat itself properly. You will find that if you hold down the lens release button and twist the lens as if to remove and reinstall the lens about 10 times that the problem will disappear. You don't even have to actually pull the lens away from the body, just press the release button and twist on and off and allow the friction to provide a better electrical contact.
Too bad Nikon doesn't tell their customers about this simple fix. Other than that, great camera. Good luck.
Posted on Sep 01, 2009
  • 4 Answers
SOURCE: I am using D90 with programe Auto ISO 400, in
additionally some remarks: I would recommend the ISO 200for daylight, as the D90 doesn't have a native 100 ISO (LOW 1). For a beginner enabling auto ISO is the better choice: this way the camera adapts to different conditions automatically, and you can never forgat to change back from ISO 1600 from the night before. If your images are dark it has got nothing to do with the ISO (ISO 400 can produce nearly perfect images in daylight). Some things to consider:
  • is the camera in the right mode (auto, P,..) if the main dial is on M, or sometimes also A, your exposure might be wrong.
  • reset the camera (the 2 green dotted buttons next to the top screen,) should erase any setting you ight heve forgotten
  • dit you shoot direct into the sunlight? also creates dark shadowed pics but this is normal
Posted on Oct 29, 2009
SOURCE: Nikon D90 ERR message after taking picture -
I have the same problem like you. I take 3 photos with my Nikon D80 and this message came out : ERR ... I have NO idea what should I do ? ! Please help me... Lucas
Posted on Dec 06, 2009
Err message in my LCD control panel. I've removed tthe battery cleaned lens contacts, put in a new memory card and still ERR message. Nikon D90
Nikon Imaging Products Support Page: http://imaging.nikon.com/products/imaging/support/index.htm
Click here for repair information.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 14, 2011 | Nikon DSLR D90 Digital Camera
My one year old Nikon D90 intermittently will not work, and will display "err" in upper left of screen, and "cha" in lower right. After some period of time, this eventually passes and...
ERR means camera error and CHA means this card cannot be used. You are probably getting the CHA error because of a camera malfunction. Try removing card and batteries with the camera turned "ON", the press and hold the shutter release for approx. 30 seconds. Replace battery and card. If your D90 has a "reset" button on bottm of camera, press that when batteries are installed and camera ON if the first doesn't work. If it continues, then Service by an authorized Nikon Service Center is advised.
Dec 04, 2010 | Nikon D90 Digital Camera with 18-200mm...
My d90 flashes an err sign somtimes when i shoot at manual mode.. but when i change my apperture and shutter speed setting, it will not appear anymore. Even at auto mode sometimes it flashes an err. Does...
Try shooting in manual mode with lens set at maximum (wide open) aperture. Then try at a smaller f-stop, say 5.6 or 8. If the error message appears when your lens is set to the smaller aperture, you could have a lens problem. Try another lens using the same test. If a known good lens gives an error message, then the problem is in the body. Also try zooming to different focal lengths and see if your 18-105mm gives the error at particular focal lengths. An error here would indicate a lens problem. In any case, your lens or body would have to be repaired by a professional as these repairs require major disassembly and re-calibration.
Nov 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
Nov 15, 2010 | Nikon Cameras
Blinking green led even D90 is off
I couldn't find a reference to a blinking green led when the d90 is off.
I would refer you to Nikon tech support for this one.
http://imaging.nikon.com/products/imaging/worldwide/index.htm
The above link has 1-800 numbers for Nikon.
Jul 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
At times my D90 camera freezes up for seemingly no reason...battery, memory card and settings all seem fine but no action. Anyone else having this problem?
There are two kinds of error messages with D90 . mainly , F-- and ERR .
F-- , this is due to lens and camera not in contact properly. So you need to take out lens and put it back securely again.
ERR - This is when camera malfunctions.
For above two problems , usually if you switch off/on your camera then this problem should go away. If not then re-insert you batteries.
If its a recurrent problem then i suggest you check with your dealer. You can also refer to manaul for the messages.
Dec 30, 2009 | Nikon D90 Digital Camera with 18-105mm...
I am using D90 with programe Auto ISO 400, in clear day sun light my picture get very dark, but on same settings in door with auto flash I get very clear result why?
ISO400 is too high of a sensitivity to use in full day light. Set the ISO outdoors to ISO100 and learn how to use your exposure compensation. The meter in the camera is easily fooled in bright contrasty conditions, so if you are getting consistantly darker shots outdoors increase the exposure compensation a stop or two. Another way is to learn how to use the camera in manual mode and you find you will have better control over the exposure.
Oct 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
