Question about Car Audio & Video
I need a factory sterio wiring diagram for a 98 ford explorer, and a interier fuse pannel diagram, thankyou
  • 32 Answers
Go to the 12volt.com for the stereo wiring, as far as fuse panel diagram no clue
Posted on Sep 12, 2010
Does any have a wiring schematic for a 98 ford explorer xlt?
Best thing is to do a Web search titled "1998 ford explorer wiring diagram". This will give you results which include fuse boxes and power boxes and color coded wiring routing. Check for other items that are on the same fuse as the turn signals to see if they work. The turn signal flasher unit could also be bad.
Sep 24, 2014 | 1998 Ford Explorer
Where is the sterio fuse in the fuse box
Mr. Doe
It's at location 11 and is a 7.5 amp fuse
http://www.autofuseboxdiagram.com/1323-1996-ford-explorer-fuse-box-diagram/
check voltage (12 volts +) to all fuses with a multimeter, not a test light. Ray
Apr 07, 2012 | Metra 96 Ford Explor/ Rangr Pwr 4/Spk
Break lighs out need diagram of fuse pannel by driver side door.
Go to this free Ford website to view or download the owners manual for your vehicle. The fuse block diagram is located in the roadside emergency section.
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Oct 07, 2010 | 2001 Ford Explorer
Ford Explorer, 1998, V6 4L the cold and hot air is only blowing HOT air from interier air unit, when swiched to cold and the air cond is not working ? thankyou dgp
Check all the vacuum hoses connected to the vacuum motors to see if they are disconnected or damaged. A fairly common one is the vacuum hose leading from the engine to the heater controls on the dash. It gets roasted from engine heat. G/L
Sep 28, 2009 | 1998 Ford Explorer
Need fuse diagram for 98 Ford Explorer Sport
If your radio does not diplay but works it is the kcd display seen many of these with this issue new radio will correct this concern no fuses for the display
Apr 27, 2009 | 1998 Ford Explorer
Electrial nightmere!
This link doesn't show a diagram per se but lists each wire and it's connection.
http://www.the12volt.com/installbay/stereodetail/857.html
Apr 22, 2009 | 1993 Ford Explorer Limited
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
