Question about Fusion REAM45020 Two Channel Car Amplifier
How easy is it to damage this amplifier ? My amp was set up on a shelf like in the back of my PT Cruzzer and the shelf busted and the amp collasped with the shelf. Then I unplugged some wires to fix the shelf and put it all back togethter but it doesnt seem to be working now the green light goes out .. this guy told me I broke it .. I find that hard to believe.
  • 32 Answers
Depends on the internals of the amp, how well it was built. its very possible that when the amp fell it could have damaged more then you know, if it doesnt power up, or if you have lost sound or quality of sound it is more then likely the amp
Posted on Sep 12, 2010
  • zebabe271 Sep 12, 2010
    I can believe that an amp is that fragile .. I should be able to test it some how .. I know nothing about it .. it came with the car .. it was a beautiful set up in the back .. just made out out cheap partical wood. I want to sell it .. this is why I ask. but thank you for your quick response.
My Technics SC-HD501. I need advice on speakers and the max range of out put i can get. I want to add two more speakers to my current setup. Whats the maximum wattage i can get? Willl i be able to add...
Looking at the specs for your system, the amplifier only puts out 23x2 watts. That means each speaker right now will get 23 watts (approx.). This amplifier is built to drive the load (the speakers) that is hooked up to it now. If you were to hook up another set of speakers, they would have to be pretty small (similar to what came with the system) with a higher impedance (over 8 would be good). The issue is the increased load/strain on the amplifier with the new speakers. However, if you are using relatively small speakers, with short run of speaker wire you should be allright (most amps have a temp protection built in, if the amp gets too hot it will shut off). To hook up additional speakers use the terminal that are there. You will 2 right speakers and 2 left. Place both positive ends of the right speakers in the positive terminal on the back of the amp (twist the ends together, if you must) and both negatives in the negative terminal, for the right speaker, on the back of the amplifier. Do the same for both left speakers.
In summary, you can probably hook another set up small speakers (which are only a short distance away from the amp) without much problem assuming you wont be pushing the amplifier to its limits all the time. You may find the amplifier lack punch or looses some sound quality though as the amp is not designed to be driving and controlling that many speakers.
Hope this helps
Jer
Jan 16, 2010 | Technics SC-HD515 CD Shelf System
Need a new amplifer for a sh-eh790 as my main audio output has gone
before throwing out your old amp open it up and check the processor inside the amp its a little black thing behind the fan. if that dont work then contact me again. and i will suggest more things. but if you really want to replace it would you give me your old amp please and here is a link to a amp for you. i know its correct as i have the same system. I LOVE TECHNICS PRODUCTS. http://cgi.ebay.co.uk/Technics-SA-EH790-AMPLIFIER-/130501062833?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item1e627830b1#ht_646wt_1141
Nov 14, 2009 | Technics SCEH790 CD Shelf System
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
Protect comes up on my hx-c6
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 12, 2009 | JVC HX-C6 Shelf System
My sony MHC-GX450 has power but does not function, power light just blinks. Any advice would be great!
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
Jun 11, 2009 | Sony MHC-GX450 CD Shelf System
PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Apr 27, 2009 | Pyle PT-2000 Amplifier
Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Apr 15, 2009 | Pyle PT-2000 Amplifier
Sony cmt-hp7 shelf system
they have some problem on the audio amplifier IC maybe are damaged
Oct 09, 2008 | Sony CMT-HP7 CD Shelf System
Amplifier
HI Skimmie
Beleive it or not, you probably need a bigger amp for the levels you are trying to acheive. If you regularly crank it and the amp gets driven to clipping, the square wave produced when the amp runs out of steam will burn the voice coils in your speakers. Best solution is to be sure you are delivering CLEAN power, not distorted or overdriven. It can be a bit hard to tell at high levels. Putting an oscillascope on your speaker outputs and check for clipping at the highest level you run is a good way of checking. Then set your max levels for that so that you cannot overdrive the amp. Clean undistorted power wont burn your speakers.
If you have variable LPF or a crossover, check the frequencies you are using also., Cross them over too high, and you will cook the voice coils also
robotek
May 06, 2008 | Lanzar HTG244 Car Audio Amplifier
Fusion REAM45020 Two Channel Car Amplifier Logo
51 people viewed this question
Top Fusion Car Audio & Video Experts
Brandon Berry
Brandon Berry
Jose Velazquez
Jose Velazquez
Matthew Spark
Matthew Spark
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
