Question about Kicker ZX400.1 Car Audio Amplifier
My 400wt kicker amp was working fine but then my boyfriend was re-arranging stuff and messed with wires and now dont work and protection light on
  • 32 Answers
Remove power from the amp let it sit for a few seconds then put power back to the amp
Posted on Sep 12, 2010
I was playing my kicker l7's and aall of the sudden they just stopped working. I checked all of the wiring and it seems to be fine. The amp turns on and works still but the subs dont work at all. Do...
Check your RCA cables to make sure you are getting signal. The amp isn't in protection is it? Also, if you have a multimeter, you can check to see if you are getting any power out to the speakers. Also, check to make sure your subs aren't blown. Keep me posted.
Aug 26, 2011 | Kicker Solo-Baric L7 12'' Car Speaker
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
KICKER KX350.4 sound fading in and out
Does the amp continue to go into protection if you disconnect the speaker wires from the speaker terminals?
Apr 14, 2008 | Kicker 04KX350.4 Car Audio Amplifier
Kicker solobarrick...still not working...
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Power Protection Circuit (SORT) Engaged
Umm a ohm meter would help you here. Double check the wires from the sub to the amp...make sure its not shorting out. Try starting the amp without the wires on the terminals...if the protection shows up then there is a short inside the unit and it will need to be replaced/repaired.
Feb 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Open Questions:
See all Kicker ZX400.1 Car Audio Amplifier Questions
Car Audio & Video Logo
71 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
