Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
How do I find my WEP key? It's not on the bottom of the unit, that I can tell, nothing that says WEP. I have an ASUS WL-520GU and a linksys VoIP phone adaptor
    Scholar:
  • 104 Answers
Only your wep server will know this.You should have had this in your router package.
Posted on Sep 12, 2010
I cant reset asus rt-n10e routr
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
Jan 20, 2013 | ASUS WIRELESS ROUTER |WL-520G - RT...
I lost my installing CD - ROM and my equiment is Asus WL-520GC/WL-520GU , can u help me? anyway, i cant even install my wireless equitment
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 29, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I can't log in to my router's web interface. I've tried the password as both admin and leaving it blank while the username is admin. The IP adress I'm using is192.168.1.1 and the ASUS router model is...
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
Jan 04, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I forgot me password for an Asus WL-520GU wireless router, how do i make a new one or change it?
Hi Dillon,
Please let me know what password you have forgotten,do you mean the one which is meant for log in to the router. open your browser and type 192.168.1.1 enter it and then check for the password.
Regards,
Gary
Dec 29, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can't get login asus wl-520gu page when i type in http 192168
Try using http://192.168.0.1 to get to the log in page of your router. The username should be: admin and password is either: admin or (no password). If this does not work, there is a reset button located on the back of your router, press this button and hold it for about 10 seconds while the unit is on, then try going to that address again.
If this still does not work, look on the bottom of your router or on the box which your router came in or the manual that came with the router. Check that you are trying to go to the correct IP Address. It should be located on the router itself, although, the standard IP Address for most routers is 192.168.0.1
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Aug 19, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS router not working with VOIP in use
check your settings if you allowed more than 1 computer to connect to your router.
Nov 15, 2008 | ASUS WL-500B Wireless Router
Asus WL 530g Router
If you press and hold the reset button on the router for about 30-45 seconds, it should reset all settings on the unit. Generally by default there is no security enabled so you will need to set this up if you want to secure your connection.
Feb 10, 2008 | ASUS WL-530g Router
WL 520 GC can only acess net in "default" before encrypting
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
Oct 24, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Philps wireless networking starter kit
hi,
You can create a WEP Key ,, and then your wireles network will be secure.
Oct 20, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
143 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
