Question about Vizio GV42L 42 in. LCD Television
Picture looks like i am watching tv inside a fish bowl
My 1987 Suzuki 250 quad racer will not crank it keeps flooding out and keeps failing my plug out It will not hit at all
Sounds like the float in the carburetor is stuck. Its inside the bottom of the carburetor inside the bowl. The bowl is just the bottom cover of the carburetor..its an empty bowl shaped bottom that fills with fuel...controlled by position of float that works essentially like a fishing bobber. Remove bowl and press the float up and down it should move freely. If there is any resistance or float does not drop down with bowl removed. The pin that holds the float in place needs to be removed and cleaned. I would also wire brush out the bowl and spray it, the float and float pin with carburetor cleaner. You do not need to disassemble the rest of the carburetor to check and clean the float. In the picture the float is #2, float pin #12, I think there are four bolts #14 that hold the bowl on.
Sep 22, 2015 | Suzuki Motorcycles
Kp-57w5510 screen loss
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
We have a canon elph. it fell into the dog's water bowl, my husband quickly fished it out. we took out all the components and dried it. i think we have both tried to turn it on. it's not looking too good....
If water got inside and you tried to turn it on, you risk frying the circuits. Bury the camera in a bowl of uncooked rice for a week, keep your fingers crossed, and try to turn it on.
Feb 27, 2011 | Cameras
Picture on screen looks like looking through fish bowl
a part called as (picture tube base ) is problemsum
Mar 26, 2010 | RCA HD52W58 52" TV
Tv turns on. There is a picture but it looks like your looking through a fish bowl. Bowes into the middle from both sides. It also looks 3D. Any Clue??
This is usually a convergence problem, although the bowing normally is from the top and bottom rather than from the sides. There may also be an issue with the pioncushion circuit that causes the bowing. Try the automatic convergence adjustment first. If that fails to resolve the problem, then resoldering the convergence ICs would be next followed by replacing the ICs should the resoldering fail.
If you wish to attempt the repair, please update this and confirm the model number to be VS-60607 and I'll provide additional details.
Thanks,
Dan
Dec 08, 2009 | Mitsubishi VS-60607 TV
Odd picture....
Yes, your convergence is off. There is a function in the menu for adjusting these propoerties. It is supposed to be done monthly but rarley is. If it is ten years old or more, the cooling fluid in the projection tubes can get low, causing fish bowl effect. Not a cheap job and time intense. Try adjusting the convergence first. It gives you three screens to aling each color then save. Good luck!
Jul 25, 2009 | Televison & Video
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
No picture or sound on tv
look inside middle of board is there 2 green leds on if there isnt take back off and see which ones out
Nov 09, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Can't adjust convergence and fishbowl effect to picture
Chances are the 4.7 ohm 1/2 watt resistors are open and the s.5 amp picos in line with the resistors may be open as well.
Jun 12, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Picture out of convergence
there are other things that has to be changed
Mar 18, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Vizio GV42L 42 in. LCD Television Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
