Question about Frigidaire ATF6000ES Front Load Washer
Start knob pulled out and won't go back in (spring loaded)knob came off
Gallery front load washer model FWT4496FS1
  • ngb43 May 14, 2008
    knob wont lock in
  • 868 Answers
Check to see if any part of that knob looks broken.It may have a locking clip that you have to place on the knob first ,so that when you push it back on it locks on.The clip is very small and looks like its shapped like a U/or V
Posted on May 21, 2008
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
The selector knob on my front loader washer the "gallery" broke off in my hand today. Inside the knob was a large spring & a metal ring. What do I do to fix this?
Just get the model number of your machine and buy a new one, you cannot fix it by trying to assemble again, spring had pressure, it may hurt you if you try to fix it, It is much advisableto replace it with new one
Nov 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Removal of the washer control knob
Anyway the model I got on your problem says it is a Refrigerator...but I can help you to remove the Knob on a washer....first you may have to place a flat head screwdriver in between the knob base and the control panel ..(You may want to place a piece of cloth against the control panel to prevent scratching the surface of same)..slowly force the screwdriver further under the knob alternating form side to side gently lifting up as you do.....(all of this is is premised on the the notion that there is no set screw in view anywhere on the knob)....also most all washer knobs are held in place on the shaft with a little spring loaded retainer that pushes out against the inside of the knob so it does not easily come off.
Hope this helps...please rate me...the Fang
Mar 26, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Mar 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
127 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
