Question about Kitchen Ranges
I have a panasonic plazma tv . model th-42phd8uk. when i hook up signal thru the componet inputs picture is green and blueish there is no red . But if connect thru video input i have all colors, and a good picture. Could i possibly have a problem with the digital board. THANK YOU, BOB
  • Bob Sep 13, 2010
    Hi e-Guru,
    We are a tv repair shop and have this unit in for repair. We know about adjusting the colors and checking the cables, could there be a problem on the digital board?
    Thank You,
    Harvey's TV
    Brigadier General:
  • 3,917 Answers
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Panasonic Plasma TH-42PM50U has blocky graphics
I need help with my TV Plasma Panasonic TH-42pm50u has a problem with blinking time 7 times in the fron of my TV Panasonic please help me
Mar 02, 2009 | Panasonic Televison & Video
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
Loud Fan
Yes, fans are somewhat the bane of these new TV technologies. With all the mechanical and optical stuf in them now, TV's are a lot less reliable than the good-ole CRT type.
Fans are easy to replace though.
Jan 03, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Panasonic multi display feature
I am not shure if the tv's are capable of multi display features. I know that some of the tv's are capable of showing multiple pictures on the same screen.
Usually the signal is sent to 1 panel and the out from that panel and into the next panel and so forth unit they all have a signal.
Dec 26, 2007 | Panasonic TH-42PHD8UK 42 in. Plasma...
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
