Question about Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-05VFL2
My panasonic fan has been working fine for the last 4 years. now, it seems to have trouble starting up... when i flip the switch on, it seems to start and re-start itself, turning itself on for 2 - 3 seconds, then stopping for a second or two; then trying again...sort of like an old car. bulbs go out, too, when it stops for that second when it's trying to start. any ideas?
  • 377 Answers
Sounds like it could be a loose or intermittent wire either in the fan itself or in the wall switch. I would start with the wall switch to see if the main power line into the switch for both the fan and light is loose. Turn the circuit breaker off for that circuit, remove the wall plate to the switch and pull the switch out of the box to examine the wires. It could also be a loose wire in the switch box that would be part of a wire splice. Tighten the wire nuts. If that does not fix the problem, a look inside the power box of the fan might be necessary to examine the wire connections there.
Posted on Sep 12, 2010
  • 2 more comments
  • rmm405 Sep 12, 2010
    this sounds like a terrific set of ideas... i'll try them and get back to you. i had been wondering if there was some safety device (eg overheat turn-off switch) that mgiht have been failing, but you make it sound like no such device exists in the fan, so your ideas on old fashioned loose wiring could do the trick. i'll let you know.
  • pwillitz Sep 12, 2010
    Please do. I will be happy to discuss it with you further in the event those ideas do not solve your problem.
  • JERRY ABELL
    JERRY ABELL Sep 13, 2010
    hello r, yes they do seem to slow down from time to time,i know mind don't run as well as when it was new,when i had the bathroom redone so i took my shop vac and cleaned out the fan blades,oh you have to remove the light,that is no big deal,unhook the wire and unscrew the 4 screws and remove lights, oh did i tell you i had a hard time finding replacement bulbs when one burnt out,had to go to a light bulb store to find them,home depot don't carry them any more,try cleaning the fan blades they get clogged up with dust and moisture and seem to run slower,hope this helps,any comment welcome,please accept my solution,thank you.
  • pwillitz Sep 13, 2010
    From an electrical standpoint, since the intermittent "outage" is common to both the fan and lights, you might want to pay special attention to any neutral (white) wire connections. One loose connection in that leg of the circuit will definitely impact both the motor and lights at the same time.
    Good hunting.
Blower fan not working
The resistor bank is bad for slow speeds, the switch is bad for high speed. In your test, you have voltage, but the switch wont carry the amps, to run high speed. Open circuits will not blow fuses. Replace both switch and resistor bank for all speeds. Make sure to clean leaves and trash from fan housing and see if fan spins freely.
May 17, 2017 | Cars & Trucks
I have had a Hunter 52" fan with a Hunter Breeze remote that has worked perfectly for almost 4 years. Starting last night when I press the light "on" button, they flash on and off at the rate of about
Sounds like a loose wire nut to me. When you turn the light on the connection warms up and the wires will expand. When you turn it off they cool down and contract. Combine that with slight vibration from the fan over 4 years it could cause a loose connection. Just pull the trim ring down and tighten all the wire nuts. The light is usually the blue wire. Dont forget to kill the power first. If that doesnt work its probably a bad remote sensor.Inexpensive and easy to replace.
Dec 13, 2012 | Dryers
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Last year my gable fan seemed to work fine. I
As it's protected by circuit breaker it also might be fused, so check for fuses.
Next just dig to the wiring and measure the resistance betveen Live and Neutral using simple multimeter. If there's no reading then there might be a small fuse (or thermofuse) attached to the windings, make sure this one is fine, if yes then motor windings are burned and you'll need new fan, otherwise just replace the fuse.
Good luck
Jun 24, 2009 | Gable (53315) Wall Mount Fan
T993 - Positive Lock Switch ?
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
Trouble with my Panasonic DVD recorder DMR-E55EB
Hi Dengle
The heat is caused by IC001 which is a regulator that is mounted on a completely inadequate heatsink on the power board. This component gets very hot during normal operation.
The regulator will usually last a couple of years, depending on how often the machine is used and then start playing up. The symptoms are intermittent operation, continuous self checking and rebooting, not being able to read discs and so on.
Eventually the component can short-circuit, burn out and take other components with it. The on-board fan is thermostatically controlled. It does not operate all the time, only when the unit gets hot enough. By using an external fan, you are keeping the unit cool enough for its own fan never to cut in. The additional cooling is probably squeezing a bit more life out of the regulator and is stopping its own fan from operating.
I have repaired lots of these and have never found a faulty fan, or fan switching fault. There's always a first time of course.
It is more likely that the regulator IC001 is faulty and if you are technically skilled, I would suggest you seriously consider replacing it. Use some heatsink compound and an extra heatsink, and it will probably do the trick. The regulator is an STRG6353. You can get these easily online from a number of outlets. Don't attempt a repair if you are unsure of what you are doing. Regards..
Nov 18, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-05VFL2 Logo
206 people viewed this question
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
