Question about E-Machines eMachines Monitor E15T4
Osd off right corner this little screen that has the brightness word and a light bulb next to it will not turn off the off button is on the right side of the monitor and some other buttons how do i shut it off i can only see three quarters of the screen
    Problem Solver:
  • 17 Answers
I sugust un hooking the cable from the moniter to the computer, asumuming it is a desktop and then see if it will turn of. If it turns of the you probably have a computer issue. Good luck.
Budman630
Posted on May 14, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
How to get rid of osd lock on screen?
Try turning the monitor off, holding the + and - buttons for brightness and contrast and turn the monitor back on release the buttons.
Next if that dosent work hold the menu button down until the osd unlocked pop up appears.
hope this helps.
Feb 04, 2010 | Computers & Internet
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
E-Machines eMachines Monitor E15T4 Logo
209 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
