Question about Gardner Bender #GSW-SK Door Switch
My SPST switch kit came apart during installation. Do you have a diagram that can show me how to properly put it back together?
  • 56 Answers
If it came apart your best bet would be to purchase a new one. These switches take a lot of pressure on them as the door is constantly being opened and closed. If you did get it back together I do not think it would last long.
Posted on Sep 30, 2010
How to dismantle my carburetor
Every carburetor has a set procedure for dismantling. If you buy a rebuild kit for yours, a sheet inside will have an exploded diagram with each part numbered. You follow the numbering guide to take yours apart. When you have everything apart by the guide, then you start cleaning and replacing what parts are in the kit. To put back together, just reverse the procedure-start with the highest number and work backward.
Aug 10, 2013 | Cars & Trucks
I have a LEFOO LF10-4H pressure regulator that I tok apart and it fell apart before I had a chance to see where all the part went. Can you show me a diagram of the switch?
I too am looking for a diagram. I am still trying just fit it back together and I have tried to get a diagram from Lefoo, no response to my repeated emails. If I do get it together I will post pics.
Dec 29, 2012 | Air Tools & Compressors
Took apart carburetor and can not get it back together
Your best bet would be to go to the auto parts store and get a rebuild kit for your carburator. You can't reuse carb gaskets anyway and the kit will include a blow up diagram of the carb with the parts that need to be replaced and steps to make sure you have the proper settings inside.
Carburators are precise so all measurements they give you in that kit are exact.Take your time. If you took the idle screws out of the front be very careful when you put them back in. Just turn them until the stop, DO NOT tighten them after they stop on the seat.They are soft and will lose their shape, making it hard to properly adjust. Hope this helps and good luck.
Mar 06, 2010 | 1985 Ford F150
Need diagram for SPST lighted rocker sw--110V
Spst stands for single pole single throw so you are only switching one wire,simply cut the wire in two and put the switch between the two ends.
Nov 25, 2009 | Electrical Supplies
I need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Apr 08, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
Galaxy DX 959
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Mar 08, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
How do I put it back together?
buy a new one, look at it, put yours back together and return the new one.
Jun 10, 2007 | Sunbeam SBCL 802 Hair Trimmer
Gardner Bender #GSW-SK Door Switch Logo
132 people viewed this question
Top Gardner Bender Electrical Supplies Experts
Gene Haynes
Steve
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
