Question about Eclipse Car Audio & Video
My rem turn on for my deck will not turn on my amp. there are three are four wires that will turn on my amp when its on fm am and xm, but the wire that turns my amp on when its on aux fm/am and xm will not work
  • zac_veatch Sep 12, 2010
    yeah im having the ame proble and cannot fugure it out the inly thing i could think of is the connect into the back of the deck is messed up and i have no clue how to fix that
  • 32 Answers
What kind of deck is it? what kind of car? its possible you have the amp turn on mixed up with power antenna wire
Posted on Sep 12, 2010
Sub problem with kenwood deck
well sounds like you crossed a wire somewhere. I would go through all the wires and check all the fuses on the amp and car.
Apr 10, 2014 | Kenwood Car Audio & Video
Kenwood CD player
Most car audio devices (like head units and amps) require a REM (remote) line to be connected to a switched power connection. This switched power is on when the car key is set to ON or Accessories.
Not knowing what Sony unit you had, I can't be sure, but it is likely your Sony had higher voltage preamp outputs than the Kenwood, as the KDC315 has 2V outputs.
Jun 30, 2017 | Car Audio & Video
Power light doesnt come on and no audio.
OK, I know you checked the fuses. So, do you have power at the inputs? Check with a voltmeter
or continuity tester. If so, do you have a remote wire connected to the REM lug. A remote wire brings a low amperage signal, usually from the head unit (CD player), back to the amp to tell it to turn on. You can simply jumper from the + side of the power lug over to the REM lug and if it turns on it means
you need to find the POWER ANTENNA output lead from your deck and route it to the REM lug on the amp. The Power Antenna wire is usually Orange on decks and is low amperage so a 14 to 18 gauge
wire will work to run to the amp. Hope this helps. If after all this still no power I'm afraid it bit the dust.
Mar 10, 2011 | Rockford Fosgate P10002 Car Audio...
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
I have a 7 in flip screen duel and a 1000 watt amp and i dont know where to hook up the rem wire for the amp to my duel
On the deck, it either has a blue or blue with white wire. It could say "ant". If it's not there, post a comment and I can do some research for you. Hope this helps
Jul 07, 2009 | Sony XM-2100GTX Car Audio Amplifier
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Wiring for kac-622 car audio amplifier
http://www.retrevo.com/support/Kenwood-KAC-622-Amps-manual/id/479bh233/t/2/
Jun 12, 2009 | Kenwood KAC-749S Car Audio Amplifier
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
Quick question about the power
The remote turn on terminal on the amp needs to be connected to a switched power source. Typically, it's the remote turn-on/power antenna wire on the head unit. If your head unit doesn't have such a control wire, connect the remote turn-on terminal to a wire that's controlled by the ignition switch.
It's VERY important to fuse all of the wires properly. If you're unsure of the proper fuse for a given wire size, read pages 14 and 16 of the Basic Car Audio Electronics site.
Let me know if you have any other questions.
Oct 21, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
After connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Mark
Oct 21, 2008 | Sony XM-1252GTR Car Audio Amplifier
Car Audio & Video Logo
63 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
