Question about Gateway Computers & Internet
Locate RAM slot on bottom of ds 200xl laptop - Gateway Computers & Internet
    Guru:
  • 1,082 Answers
With the information you gave, I cannot find your computer.
The memory slots are on the bottom of the laptop. Generally, there is only room for two cards so if you want to upgrade, you have to take out one card to put the new one in.
Posted on Sep 12, 2010
How to install memory stixs
In an Acer Extenza 5420 series of Notebook PC?
Well you came to the right place
Here have a seat, and let me show you;
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Here is a Bottom view of your laptop,
http://www.ebay.com/itm/Acer-Extensa-5420-Case-Bottom-15-4-Black-Cover-Speakers-Original-Genuine-Laptop-/170983023419?pt=US_Computer_Cases&hash=item27cf61e33b
Bottom left corner shows the Battery has been removed.
Remove the large panel above it,
http://www.ebay.com/itm/Acer-Extensa-5420-5520-Hard-Drive-RAM-Memory-Bottom-Cover-Door-60-4T305-002-/190741766831?pt=LH_DefaultDomain_0&hash=item2c691862af
Looks to be 6 Philips head screws to remove.
The panel lifts up on the LEFT side. There are TABS extruded from this large panel, which go into the Base Enclosure, (Bottom Cover), on the Right side.
From the Specifications on Acer's Support website,
http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5420/Extensa5420sp2.shtml
,it states;
System Memory: -> Up to 2GB of DDR2 667MHz memory; upgradeable to 4GB using two SO-DIMM ram memory modules.
(Dual-channel support)
From what I can see, looking at the motherboard by itself; there are TWO ram memory slots,
http://www.ebay.com/itm/Acer-Extensa-5120-5420-7120-7420-TravelMate-5220-AMD-Motherboard-MB-TKP01-002-/350455821339?pt=Motherboards&hash=item5198cb741b
Towards the Top you see the White processor socket. Upper corners are cut off, and there is a single screw in the top/middle.
Right above it are two white Ram Memory slots.
EACH ram memory slot will support (Use) 2GB of DDR2 at 667MHz.
2GB = Amount
DDR2 stands for DDR2 Sdram, and is it SO-DIMM to fit in a laptop.
667MHz stands for 667MegaHertz.
The frequency rate ('Speed') that the Ram Memory operates at.
The TOTAL amount of ram memory for the laptop is 4GB.
That means you can use two modules, ('Sticks') of DDR2 Sdram at 667MHz.
Or also stated as PC2-5300.
Just make SURE it is SO-DIMM, or you will be getting the larger DIMM ram memory used in a desktop computer.
An example of SO-DIMM,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Side Notch on Each side.
The half-moon cutout.
Note the Locating Notch on the Bottom.
Also;
Everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the Bottom; is the BODY.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the Body.
Refrain from touching the gold plated contact pins.
[WORK on a table. {Or workbench} DO NOT work on a bed, couch, or directly on a carpet floor! High areas of Static electricity.
Static WILL fry out, (Short Circuit) computer hardware components]
If you have two Ram Memory modules, one will be stacked on top of the other one. You remove the top one first, then access the bottom one.
To remove a ram memory module, simply ease the spring clips on either side -> OUT.
Out away from the Ram Memory module.
This action takes the 'Bumps' on the Spring Clips, out of the Side Notches on the Ram Memory module.
DO NOT get carried away. Just ease one spring clip out, then ease the other one out. You can bend the spring clips if you are too rough.
When both spring clip 'bumps' are out of the way, the Ram Memory module will spring up slightly.
Remove AT THAT ANGLE.
Slide the Ram Memory module out, at the same slight angle, (30 degrees?), that it just popped up to.
IF you lift the Ram Memory module straight up, you WILL damage the gold plated contact pins on the bottom of the Ram Memory module; and the contact pins in the Ram Memory slot.
To install a Ram Memory module, look at the location of the Locating Notch on the Bottom.
This aligns with a Locating Lug, in the bottom of the ram memory slot.
ONLY goes in one way.
Locating Notch aligned with Locating Lug, slide the Ram Memory module in, in the SAME slight angle it came out at.
Make sure the gold plated contact pins of the Ram Memory module, are well seated in the ram memory slot.
(Ram Memory module is pushed in tightly, in the Ram Memory slot)
Then press down on the tilted up side, until the spring clips lock in place.
Here is a video demonstrating the above, but NOT your laptop,
http://www.youtube.com/watch?v=MbPaR1Ci-Ug
IF, you are ONLY installing ONE Ram Memory module, it MUST go in Slot 1. Also known as DIMM 1.
The Processor (CPU) reads what is in Slot 1 -> F-I-R-S-T.
Know this;
If you are using the regular Windows XP Home, or Pro; it is the 32-bit version.
If it is the Windows XP Pro 64-bit version, it will state so.
Either on the body of the laptop, or go to System Properties.
[Left-click on Start > then Right-click on My Computer.
Left-click on Properties at the bottom of the drop down list ]
Windows Vista 64-bit will state so also.
Point?
IF you have a 32-bit Operating System, your laptop will ONLY recognize about 3.2 to 3.5GB of ram memory; if you have 4GB installed.
Takes a 64-bit Operating System to recognize all 4GB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 06, 2013 | Acer Extensa 5420-5687 Notebook
How to install ram memory on e644g-0663 laptop
http://support.gateway.com/us/en/emachines/notebook/2011/eMachines/eme/eme644g/eme644gnv.shtml
http://support.gateway.com/emachines/notebook/2011/eMachines/eme/eme644g/eme644gsp2.shtml
Up to 8GB of DDR3 Sdram ram memory that is SO-DIMM for laptops, and 1066MHz.
That is PC2-8500 that is SO-DIMM
An example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4505186&CatId=4153
There are TWO Ram Memory slots. EACH one has a maximum amount of 4GB.
Total Maximum Amount of Ram Memory is 8GB.
IF, just one Ram Memory module ('Stick'), is to be used, it is placed in ram memory Slot 1. (DIMM 1)
(The Processor reads what is in Slot 1 first. Cannot have ram memory in Slot 2, and not Slot 1 also )
What?
No that's okay Acer/Gateway/eMachines!
I have access to the SERVICE MANUAL, bahahahaha! Your lack of info doesn't bother us...........
http://www.manualowl.com/m/eMachines/E644G/Manual/258030
This is a PDF file. Scroll the page down using the scroll bar all the way to the right, until the top header of the PDF file reader shows.
To the immediate right of the number 216 at the top, is the Page Down Arrow.
To the left of the number 216 is the page number box.
The PDF reader page numbers do Not match the actual manual's pages.
Put your mouse cursor in the page number box.
Backspace the 1 out.
Left-click once.
Type -> 95
Press the Enter key on your keyboard.
(In the Top header is also the controls for view size.
To the left of the page number box is a Slider that is a blue 'Dot'.
Left-click on the blue 'Dot', hold the left mouse button down, and drag it to the left to Decrease the view size.
To the right to Increase view size )
Under the bold subheading - Prerequisite, click on the blue -
Base Door removal
Bottom of laptop facing you, open Battery Compartment to the Top, away from you, the Base Door is at the bottom.
Rectangular cover that has two Philips screws holding it on.
One screw at the Top/Middle, one screw at the Bottom/Middle.
Remove these two screws, do not lose them. (Double-sided sticky tape to table, and stick the screws to the tape )
BEFORE beginning;
To go on;
This is a general example of a laptop SO-DIMM ram memory module,
Note the Locating Notch on the bottom, and the two Side Notches on either side.
The Locating Notch at the bottom, lines up with a Locating Lug in the bottom of the ram memory slot.
For this reason it can ONLY be installed in one direction.
There are spring clips that 'snap' into the Side Notch/es.
The top of one spring clip is eased to the outside of the laptop.
Now ease the other spring clip to the outside.
Once both spring clips are freed from the Side Notches, the ram memory module should pop up a little.
(Sometimes you have to keep one spring clip, held out with one hand, and with the other hand move the other spring clip out )
Remove the Ram Memory module, at almost the SAME angle as it is now. Slightly tilted.
DO NOT bring the Ram Memory module straight up, or you will damage the gold plated contact pins of the Ram Memory module, and also the contact pins down in the ram memory slot.
Notice how ram memory in Slot 1, (Slot A), is on top of the ram memory module in Slot 2. (Slot B)
If you have two ram memory modules installed, you have to remove the top ram memory module, first. (Slot A)
Again, if you are just going to use ONE ram memory module, it goes in Slot 1 (Slot A)
Look at the ram memory slot, and the Locating Lug in the bottom, and/or observe which way the Locating Notch on the ram memory module was, before you took it out.
Line the ram memory module up with the Locating Lug.
Install it at the same angle roughly, that you took it out at.
Once in the correct position the spring clips 'bumps', will snap down into the Side Notches, of the ram memory module.
(Click / Click)
Reinstall the Base Door.
Reinstall the Battery.
Attach the AC adapter (Charger), and plug the AC adapter into power.
(ALWAYS plug into the laptop FIRST, then plug into power. Otherwise a power surge could happen, and burn out electronic components in the power section of the motherboard)
WAIT 1 minute, turn the laptop on. BIOS will recognize the ram memory. You're done.
http://videos.howstuffworks.com/howstuffworks/49-how-to-add-ram-to-a-laptop-video.htm
Regards,
joecoolvette
Oct 22, 2012 | eMachines Computers & Internet
Where are ram slots in packard bell
Most laptops RAM slot is located on the bottom of the laptop behing a small re-moveable panel.
Oct 14, 2012 | Computers & Internet
Only one ram slot works
Latops have two RAM slots and they usually are located on the bottom of the laptop.
If you see only one RAM slot on the bottom of your laptop then this is RAM slot is number 2, the other RAM slot is located under the keyboard and this memory slot is RAM slot number 1 and the first RAM module in installed in this RAM slot.
Jun 01, 2012 | Computers & Internet
Upgrade RAM in my laptop
Most laptops have a panel on the bottom of the laptop where the RAM is located. Remove this panel to get access to the RAM slot/s. If there are two RAM slots then you can insert larger RAM modules in these slots to increase your RAM requirements.
Feb 16, 2012 | HP Computers & Internet
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
I can only find one DDR ram slot!! there is only one slot behind the panel on the bottom. where is the other slot located. I have the tecra m2v-s330. should i just take it apart to look for it...i have...
The 1st RAM slot is under the keyboard. This slot has a RAM module installed when you purchase the laptop. The 2nd RAM slot is on the bottom of the laptop.
For removal of keyboard and keyboard replacement check out this WEB site.
http://www.batterycentury.com/toshiba-tecra-m2v-s330-keyboard-p-79168.html
Apr 14, 2011 | Toshiba Tecra M2V-S330 Notebook
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
Where is the second slot for memory ram on m3000n
you will have to remove a cover on the bottom of the laptop where the ram is located ...most laptops have 2 slots for ram , but there are some that only have one slot ...if you google the model # of the laptop then you should be able to find out how many slots your laptop has and the total amount of ram that it will accept.
Feb 07, 2010 | ASUS M3000N Notebook
Computers & Internet Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
