Question about Sylvania G-Netbook
Sylvania netbook: need data for "Wireless Network Properties": credentials?? activation key? Where do I find that?
    Brigadier General:
  • 10,406 Answers
It is the wireless router that needs to be configured to set an SSID, an encryption-level (use 'WPA') and a password/passphrase.
Configure the router, and then use those settings to configure the wireless adapter on your netbook.
Posted on Sep 12, 2010
  • sdockery1 Nov 26, 2010
    I think I am having a similar problem. I have the Sylvania 7" Netbook with Windows CE 6.0. I have a Clear Hot Spot Device (which I am using on my full size laptop now, so its working). The mobile device recognizes and says it is connected to my Hot Spot, but when I try to open a page, it cannot be displayed. Clear tech support suggested I call digitalgadgets (maker of the netbook) for advice to configure the netbook, but they have been unavailable. I need help. I went on their website and it said to download the WiFi Patch (RT2870.arm.CAB file), but I don't know what to do with this? Any help?
Trying to connect my netbook to the internet
Computer side 1) Make sure your netbook wireless drivers areworking/updated 2) Deleted the unwanted / unnecessary hardwaredrivers inside your PC a. Go System Properties > Advanced >Environment Variable b. Add this inside system variable "devmgr_show_nonpresent_devices"-value 1 c. Restart your PC d. Go System Properties > Device manager >View > Show hidden Devices e. Delete those device items with the "faked" icons Network Side 1) Go to wireless setting inside your router 2) Under advance setting/ wireless setting Change the a. DTIM Interval: 1 b. Fragmentation Threshold: 2306 c. RTS Threshold: 2307 d. Beacon Interval: 50 See if the network connectivity is better Happy Troubleshooting
Mar 10, 2011 | Sylvania G-Netbook
Why cant i connect to my wireless network
go to network settings and check if thereis any exclamatory sign on network between computer and internet.if yes then u have have to change the setting of ur wireless connection.but doing it manually you canchoose the network available and the password provided by the internet service provider.
cheers!
SS
Mar 05, 2011 | Sylvania G-Netbook
Can't get on the internet have sylvania 7" netbook.
t is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Dec 31, 2010 | Sylvania G-Netbook
Unable to set up Netbook on Sylvania 7" Netbook
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
Dec 29, 2010 | Sylvania G-Netbook
I recieved a Sylvania 7"
You can take the SYNET07526 out to a McDonalds, they have a open wirless network that does not require a password and it will link up allowing you to surf the internet.
You could also ride around neighborhoods and see if you can pick up any networks that are not protected. This is refered to as War Driving.
I need help putting wi-fi on my 7 inch sylvania netbook. how do i get internet to work
Dec 28, 2010 | Sylvania G-Netbook
My 7in sylvania will connect to other connection away from home, but won't connect to my wireless at home
You have to click on the WiFi button and make sure that you turn it on, and what is left is Turn Off button.
Wait for the little computer icon in the lower right corner to show two radiating side waves with a red X under the icon. The red X indicates that the WiFi has not connected. double click on the Computer icon and a window opens up with RT28701 as the header, with all zeros in the fields.Click on the tab Wireless Information. and a new window opens up. Look for the name of your home wireless network, and double click on that name. another window will open up called Network Properties and you will see some entries, with the name of your network as the SSID. go down to the key box that says The key is provided automatically, and uncheck that box. At the long box that says Network Key type in your code for the network key. This code was assigned when your network was set up to prevent someone else from accessing your network. When you finish, check the box The key is provided automatically and from then on your machine will connect automatically because it will remember your key. See:
http://digitalgadgets.com/netbooks/support-7in-netbook.htm for the same information.
Dec 19, 2010 | Sylvania G-Netbook
Bought daughter a 7" Sylvania netbook for X-mas,
See: http://digitalgadgets.com/netbooks/support-7in-netbook.htm for a detail of how to connect. If that does not work then see my how to at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
You may also see:
Dec 18, 2010 | Sylvania G-Netbook
How do i find the modem number for (the network key) under the wireless network properties?
Are you trying to find the WED key for the wireless network you are on? If so what OS are you running?
Nov 29, 2010 | Sylvania G-Netbook
I bought the new sylvania 7" laptop. I am having problems.. We have connected to our wireless router however, we not get on the internet...
from another computer, go to the routers configuration screen and make sure the status shows that it is connected to the internet. Also the routers internal LanIP address must be 192.168.1.1 for the netbook to work.
Sep 19, 2010 | Sylvania G-Netbook
Sylvania G-Netbook Logo
1,035 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
