Question about Yamaha RX-V2092
When you turn the power button on it stays on for a second and then turns off
    Problem Solver:
  • 7 Answers
Might be problem with powersupply or firmware
Posted on Sep 15, 2010
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
My 7410 will not power up. The "HP Advent screen appears to just idle along and the only thing that changes it is to disconnect the power cable.
If the printer powers on and stays Idle with HP logo screen, you try reset the printer as below (try next step one after the other, if it doesn't fix)
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 22, 2011 | HP OfficeJet 7410 All-In-One InkJet...
I turn my iphone on but it wont load up the apple stays on cant do nothing
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
Nov 10, 2009 | Apple iPhone Smartphone
My VS-60607 won't turn on
there is a fuse blown in the television keeping it from staying on. after the shutdown press and hold the menu and device/input button for about 5 seconds and the led will blink a 2 digit code with a pause in between. the code will repeat itself. 2.2 is the most common and points to the convergence ics and 1 or 2 5a pico fuses. 2.3 is the next most common and points to a fault on the power supply. goodluck.
Feb 05, 2009 | Mitsubishi VS-60607 TV
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Turn on and stay on
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Nov 06, 2008 | Televison & Video
Power will not stay on
what is the model number of your set?
Mar 09, 2008 | Televison & Video
Yamaha RX-V2092 Logo
202 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
