Question about Electrolux Epic 6500 Vacuum
Bag was changed, but vaccum cleaner will not reset itself
  • 694 Answers
You could have a clogged hose, afterfilter, or worn/broken control valve assembly.
1. To check the filter, press the tab located at the bottom of the tool holder/air diffuser. See photo below. Lift air diffuser. There may or not be a filter here. If there is, remove it, then check machine operation.
2. Disconnect hose form canister. Turn on machine. Place hand over intake. If the machine turns off during this process, the control valve assembly is broken or worn out. Replacement needs to be done at an authorized Aerus franchise service center.
3. To check the hose, disconnect both ends. Drop a marble or similar size item in one end and allow to roll out the other. If it doesn't, the hose is clogged. This will cause the machine to shut off as well.
Posted on Sep 24, 2010
Testimonial: "Thanks"
  • massoud101 Oct 23, 2010
    Roger, is replacing control valve something that I could do? Could you please explain how a DIYer could do this? My vacuum cleaner exhibits the behavior you described in number 2. I don't have a clogged hose but attaching the hose to the unit turns the machine off.
  • mrclutch Nov 01, 2010
    No. The machine has to be disassembled to get tothe control valve. This is not a job for a "weekend warrior." This should be done by an authorized Aerus/Electrolux repair person.
2 Suggested Answers
  • 43 Answers
SOURCE: Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
Posted on May 07, 2009
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
How i clean cloth bag sc886 vaccum
well if you must clean it,,(not a good idear to do so) you could throw it in the washer by its self! but its far better to put a new cloth bag into the vaccum cleaner,, a washed cloth bag wont work half as well as a new bag will,,all you will get is even more dust out of it,,,thats twice the cleaning,, buy a new bag and save the time and work
Jun 25, 2010 | Eureka SC886 Bagged Upright Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
Dec 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Have the cannister 6500 SP just changed all filters but when I start the vaccum it shuts itself back off and the full bag indicator light comes on?
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Jun 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Just powered itself off
It will shut off if your bag is full. If you are cleaning up fine dust, it will give a false bag full indication. Take the bag out and carefully, shake it down to get the dust out of the filter layers inside. This will let more air flow through the sensor.
Nov 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Bissell vaccum cleaner belt change
I need instructions on how to change the belt
Sep 09, 2008 | Bissell 3522 PowerForce Bagged Upright...
Changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Dec 31, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
455 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
