Question about LG WM-2277HW Front Load Washer
I have an lg tromm front load washer and it keeps displaying an LE code. Is there a fix for it
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine
Peace,
ngafm at your service!
Lets try this first!
Unplug the washer for 5 minutes and then replug and try it to see if this reboots the system like when a computer acts up, we do the same thing for most electronic devices!
If for some reason this is not helpful, open the user guide and see what the tell you is the meaning of a code"le" on your specific machine!
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Jul 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
383 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
