Question about Whirlpool Duet GHW9150P Front Load Washer
Washer comes up with sd code.we use he soap always.washer fills and washes justfine.rinses just fine.but when it spins the sd light comes on and in a couple of minutes it will shut off. model wfw8300 sw04
  • Anonymous Mar 30, 2014
    the electronic motor board got replaced on my washer but still giving me a sd code. what else can be the problem?
    Brigadier General:
  • 3,917 Answers
Hi
SD would be too much suds or the pump or filter is clogged and can't remove the water fast enough.Remove the front pa
nel and check the pump filters for objects.
If it reads "Sd," it means that suds are detected and you are using regular detergent. Only use laundry detergent specifically for high efficiency washers in your Whirlpool Cabrio washer. Another reason the "Sd" code may appear is too much detergent. Use only the amount recommended. More won't get your laundry cleaner.
Please check the bellow links for your referrence:-
http://maytag.custhelp.com/app/answers/detail/a_id/2948/~/display-shows-sud-or-sd---front-load-washer
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 12, 2010
Error code sd
sd means suds, for either the wrong soap was added or just had too much soap. Rinse out washer, you can use a small cap full of oil (like the oil cap) to deactivate the soap. Then rinse out washer again, this should fix or correct this issue.
Good Luck
Aug 04, 2014 | Whirlpool Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My top loading washer has an error code of Sd, don't know what that means??
Sd means suds was detected. "Sd" is displayed when the control senses drag on the basket. Too much soap makes the motor work harder causes it to overheat and generally suffer a beating. The wrong soap also triggers this. Also An item of clothing jamming the basket can trigger this warning. The control has a program to remedy it. Filling, rinsing, and rechecking all in the name of making sure yall's clothes ain't got no soap in em. If the control cannot fix the probo after trying a bunch of times, then it declares an error has occurred and everythang comes to a screechin halt.
Cabrio Washer Service Manual
Mar 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The water is still soapy after many rinses. I am using very little soap
I am having the identical problem with a Maytag washer! The first 2 or 3 rinses are effective somewhat, (but not like the Whirlpool I had for 22 years) and I think, "one more for fabric softener"---but suddenly I have a full inch of bubbly white, white, very soapy suds! Picture half a washer of water with a cup of tide! It's that soapy and I cannot figure out where the soap is coming from! Tonight, I had not even used a regular soapy detergent in the previous 15 cycles, having switched to an eco detergent from Costco and used little. I even ran a few cycles with no laundry and no detergent--no soap then!
Btw, the washer has only cold water rinses--I had not noticed the tiny print on the front of the washer--or I'd never have bought it. We learned in fabric class that icy cold water (it's snow melt here in Oregon) shocks fabric as badly as hot water, and it fails to get soap out as well. And everything comes out scratchy stiff like cardboard, and hurts my face--skin even peeled before I began opening lid to check on rinse cycle. I got rashes and dry skin from all the soap and ice water...until I began doing 7 or 8 rinse cycles on the items like washclothes, towels etc. Clothing gets hardly any soap, or I hand wash it now--am exhausted and want new machine! Can't sell this junk tho.
Anyway, so the way I rinse with warm or cool (not melted snow) water is I stop the washer and start over the wash cycle to get warmer water for the rinse. Then, I move the dial to extra rinse cycle for the rest of the rinse, after the water has filled, so it cannot go on to do an ice water rinse after competing the "wash" cycle that's really a rinse cycle with no soap.
I would hurt the person who designed this washer! It seems to add soapy water back into the rinse on the 4th rinse cycle! Sounds bizarre, but I always think that everything is finally rinsed ok and one more with a little fabric softener will do it, but when I look inside to add the downey, there's an inch of suds on top! I don't have suds like that on my wash cycles! It's bizarre...I've wondered if neighbor's suds are coming in, or am I haunted?
Last week, I hand-rinsed my washcloths and kitchen towels and put them in washer for the spin cycle, at end of the rinse cycle, just to get water out of them for dryer.... To my dismay, the spray of water while spinning (have no idea why washers add icy snow melt to my warm rinsed laundry during the final spin but they all do, you can hear the spray) was soapier than my original wash cycle--which has a teensy bit of suds which is gone in a minute or 2! Honestly, my washcloths etc were fully soapy again! I'd rinsed them so well that immersing them in warm water left the water clear and clean, but after the spray, they were just as soapy as after the earlier rinse cycles that had the inch of suds... I had to take everything out and spend another hour hand rinsing and wringing befor the dryer....
I have taken to using pint-sized tupperware to get the suds off the top rather than letting it go into the laundry or washer. I skim it out and put it down the kitchen sink. It's so soapy I'd have to do dozens of rinse cycles to rinse it out, so I skim it out manually. So new soap must keep getting into the washer! It also does not seem to matter whether the wash is full or half. Tonight the previous rinse cycle had been full, and pretty clean. But when I o;pened the next one to add fabric softener, it was only half full of water, and an inch or soap suds. I had wondered if the soap was outside the basket, and came in through the holes, once water got that high, but no. Does not matter. And I had wondered if it was caused by suction from stopping the rinse cycle during spin...but I went load after load for 10 days, never stopping a cycle early and it still put all that soap in the 4th rinse cycle. Or in the 3 cycle's spin at the end of rinse, when it sprays water on the spinning laundry.... This is a horror. Maytag ignores my emails. The handyman says new washers are terrible and wants nothing to do with it. I wish I'd paid whatever it took to fix my old whirlpool. 22 years and never an issue ever, never more than 3 rinses and then only a 3d because I'd used double soap to get out dirt from gardening or road trips like Santa Fe in the winter when shih tzus got covered with red clay dirt used on snow and ice--that stuff is lethal! Normally I added fabric softener on 2d rinse cycle and things were so clean. Now things are not clean, come out ripped, or with pilling like they aged 10 years in one night. So I handwash anything I want to keep nice. Washcloths are getting frayed, towels look bleached or faded....and I am relating to my grandmothers on wash day. Sorry it's just more problems not solutions.
Jan 23, 2011 | Kenmore Washing Machines
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool Duet GHW9150P Front Load Washer Logo
171 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
