Question about Zanussi FJS1225W Front Load Washer
Zanussi fjs1225w nasty smell around door seal and inside machine
Have an awful smell coming from machine have checked pipes and used products to clean machine nothing seems to work.Door seal is dirty but not rotted have you got any ideas
Are yo;u susing front loading detergent? My smell went away when i switched.
Posted on May 29, 2008
Drum smells
Open the door and run your hand deep inside the door seal. It probally has a slime around it. You can clean this with a bleach water mix. You might need to pull the seal somewhat inside out to get it real clean. Then run an empty load to flush it all out. Here is a link for replacing the seal or spring clips if you pull one off. http://appliancehelponline.com/washerdoorseal.html
Jul 07, 2010 | Hotpoint Aquarius WD640 Front Load...
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
It is leaking water from the bottom as it washes
Plug off the mains. Open up the washer top & behind. There should be a loose or torn rubber pipe. Examine all hoses (pipes), including door seal. Three pipes go from the inlet to soap holder, below the drum you will find a big hose to the filter and pump. If you cannot find anything turn the machine on (keep kids away, locked out). Run the machine without clothes or soap to observe where the leak comes from. You can either tighten the hose, with mains off or replace the hoses. Try sites below for spares with make & model number, depends where u are.
marcone.com
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Feb 12, 2010 | Zanussi FJS1225W Front Load Washer
My front loader is driving me nuts. everytime I
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Feb 05, 2010 | Zanussi FJS1225W Front Load Washer
Change the door seal
Not sure if its the same type but I just changed the door seal on a Zanussi ZWF1221W washing machine. It was a lot easier than I was expecting but this way does take a bit longer. Before starting disconnect the mains and water supply and drain hose. If possible move the washing machine out so you can get around it.
First I used a small flat head screwdriver to open the teeth on the outer door seal clamp that holds the seal in place. The old seal then peels off the front of the machine. You can continue the process without taking the front of the washing machine off but it is much, much easier to take it off if you can.
To remove the front panel unscrew the two bolts at the top corners of the back panel and slide the top cover off towards the back and lift it off. Then remove the two bolts that attach the plastic control panel to the front of the machine (either end of the top, front edge), remove the detergent dispenser drawer (you need to push down on a lever at the back) and take the screw out of the front of the machine (revealed when you take out the detergent drawer). Then carefully remove the control panel and the two bolts that hold the front panel on.
Then (very carefully as washing machines are heavy) lie the machine on its back and remove the three screws from the bottom that hold the front panel on. Then unplug the cables on the inside of the front panel that operate the door lock (its a plug with a plastic cover - just pull it out but don't pull the wires!).
Now you can lift the front panel off which is the key to making this job really easy as you're not trying to fit the new seal through the door which makes it really tight.
With the machine still on its back find the spring that stretches all around the seal to hold it on the drum and remove using a flat head screwdriver to pull it out of its groove. You can now pull the old seal off.
It's a good idea to put some fabric softener or liquid detergent around the edge of the new seal to make it easier to fit on to the drum at this point.
Find the arrow that points to the top and starting here attach the groove of the new seal to the plastic drum all the way around. You have to press quite hard but you can tell when its properly attached to the drum. Once this is done replace the spring so it sits in a groove on the seal holding it to the drum.
Now replace the front of the panel of the machine by doing the reverse of all the earlier steps (remember to reattach the door lock) and stand it back up on its feet (careful it's heavy). You can now replace the top panel of the machine (slide it on and replace the two screws).
With the washing machine back upright you can attach the front of the seal to the door opening of the front panel (the arrow should be pointing upwards). Then you can reattach the clamp that holds the seal around the door opening and then secure the teeth on the clamp so it's tight (I don't know if it matters where around the seal the clamp goes but mine's at about 7 o'clock).
Now all you need to do is reattach the drain hose, water supply and mains and test it doesn't leak. A rinse cycle uses the most water apparently so it might be worth using that.
Hope this was useful.
May 23, 2009 | Zanussi FJS1225W Front Load Washer
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Smelly Water Draining
Try getting the new whirlpool affresh washer tablets. They clean the mold and are supposed to make everything in the washer smell better and keep it clean. They are only around 10 bucks and is worth a shot to clean your smelly drain.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Oct 09, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Nasty water accumulation from washing machine
Posted by Jay on Jan 11 2009
I have the same washer now for several years now. I keep getting the smell now and then. After reading all these disappointed people I went down to the machine and cleaned out the "Pump filter". It had been smelling today, I was tired of this problem also. So i opened the little door at the bottom front left corner. There you find a little black hose, pull it out a little and pull the plug. There you drain the water that's laying inside smelling up the house. Now you un-screw the big black cap. Once you remove the cap, you find a plastic filter-catcher. I found paper, a dime, and several other things that came out of my pockets. You can take the basket to the sink and wash it out. Put it back together and try checking it in one month. Also I used some needle nose pliers to clean the nasty stuff around the gasket. At the bottom of gasket try pulling it back to get to the hair and ****. We have a dog, so the hair is bad.
Sep 22, 2006 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Zanussi FJS1225W Front Load Washer Logo
387 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
