Question about GE WBSR3140DW Top Load Washer
I had my ge washer half apart today to check for a leak in the pump system or something, I couldnt find anything wet really or corroded on the pump so i put it back attatched water and started it, worked normal. So, I get the washer back inside, put in some laundry and fired it up like I did before, and sure enough water just flows out the bottom until i turned it off. I pulled the front off the washer and turned it on and saw that the water is pouring out the left side, or opposite side of the pump from a plastic tube coming from the top of the tub the clothes sit in. Why is it leaking now when its full and not when its empty, and how can i stop this??? please help.
  • mmspookykid6 Sep 12, 2010
    ok, the troubleshooting guide is for a different model washer, mine is a WBXR1060T3WW GE washer. sorry for the confusion. also, your comment would make sense if there was another inlet to the pump for it too go on, but like i said, its on the opposite side of the outter tub and not even close to the pump. the plastic tube im talking about is a round hard plastic tube almost 2 inches in diameter and is attatched to the outter tub towards the top of the washer. its attatched to the side of the outter tub and comes down below the motor and belts and just has an opening, nothing hooks up too it, its just open. i think its like some kind of vent or overflow? but why would water come out so fast out of there when its running and now while its sitting there off no water is coming out yet its still full? also its still in the ossilating stage, no water is entering no water is pumping out, just ossilating full of water an it leaks when its on, but not off.
    actually no, it wasnt very helpful. i understand i didnt give the right model number and the troubleshooting guide was different from mine, but at the same time i mentioned that the issue i was having wasnt connected to the water pump and yet he said that the problem was that it wasnt connected right to the pump. i said the tube water was leaking from wasnt by the pump at all, in fact on the other side of the washing machine. didnt seem like he was understanding what i was writing, and if that was the case he shoulda asked me for more info about what i was talking about it seemed like he just shot out the most generic answer and not even relavant to my question. then i sent a comment to tell him more cause i didnt think he understood and gave him the new model number of the machine and i never heard back. i know i only picked the $6 option but still he never even tried it felt like. what a complete waste of $6, tell silverdragon he can shoove it up his *** when you pay him for doing nothing.
  • GE Master
  • 12,061 Answers
Http://appliancejunk.com/ge/washer/31-9103.pdf
Please find your service and repair manual above, this will assist you to troubleshoot this issue.
Below is a DIY troubleshooting site to assist you.
http://www.repairclinic.com/Washing-Machine-Troubleshooting
You may find it's leaking due to the fact the tube isn't sealed against where it mate to the pump, but there could be a few similar reasons, please use the troubleshooting steps to isolate.
Posted on Sep 12, 2010
My washer is leaking and won't agitate properly.
I had a similar problem with my GE Washer that leaked, and still won't spin. I fixed the leak though. It was from the pump, which is in the bottom front, and somewhat easy to get to. I just removed the front cover, and the pump is on the right side. The pump itself was not broken but one of the screws was corroded with rust, so water leaked from that area. I just had to take it apart, put in a new screw to get a tight seal, and no more leak.
Mar 11, 2015 | GE Spacemaker Washer and Dryer Electric...
Why is my GE washing machine flooding from bottom?
Chill out Mr. Sir. This is where you get to be a hero today.
Fortunately for you, washermachines and dryers are rather... big dumb equipment for the most part.
I highly advise you take apart the unit. They are big, but they are also simple. They are designed very well to be taken apart with minimal tools and experience. The panels usually unlatch after 2 - 8 screws. The wiring is simplistic and easy to follow with the eyes.
Something like a water leak should be very easy to find. You'll most likely find a cracked plastic fitting or something else that is crude and simple in form. I'm willing to bet that a simple treatment with epoxy glue or 30 minute cure super glue could fix it just fine. And even better if you find something that only needed a fixture to be re-situated and re-tightened.
Washer machines can vibrate allot so most likely you have something cracked or fallen loose. If you've ever had a washer or dryer repairman come over to fix something, they are usually done within 30 minutes. An average Joe like you could most likely get the job done in 3 hours or less.
Apr 25, 2014 | Washing Machines
Our GE front load washer model #GBVH5200J2WW quits in the middle of the cycle, any ideas why?
Check and see if you get any code when your lights are flashing when it stops ?Alot of the times your screen inside of the hose stops up Turn off the water going to the washer and take off your hoses and look at the screens if they are dirty replace them .If it stops and your clothes are still verrrry wet then you have sucked something inside of the pnmp .Take off the bottom cover and you will see a grey rubber thing that hooks to the bottom of the tub then it hooks to the pump take a good pair of channel locks or agood pair of pliers and take the little hose off the pump and you sould see something in there like a baby sock a small washcloth or anything if you find that then you are set .Good Luck
Oct 15, 2011 | GE Washing Machines
Overheated, not enough to hurt anything. Saw a puddle under the car and couldnt figure where it is coming from. Seems to be near the water pump. For the kicker it is not leaking all the time just here...
Check behind the water pump pulley. If it's wet, the water pump is leaking. Sometimes the water pump seal will leak intermittently until they finally give in the ghost. In the meantime also check all of the small hoses from the area of the pump to make sure it isn't one of them.
Jun 27, 2011 | 2005 Suzuki Forenza
Spin cycle starts, speeds up, then stops spinning
This fault often occurs when something (like a small coin or a paper tissue) has blocked the drain pump!
The only way to fix this would be to get a service engineer to remove the pump and check for a blockage, unless of course you are an experienced electrician or technician and don't mind doing it yourself.
Nov 18, 2009 | GE WBSR3140DW Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
Washer is leaking when draining...
Ok..so you checked al the hoses.. do you mean ALL the hoses inside the washer? or outside the washer.. chances are one of the hoses broke free durin the violent spin cycle of that over-sized rug.. and you haven't found it yet. If you have sufficient room to extend the washer out from the wall.. gain access to the inside of it from the back.. then check each and wvery hose connection/clamp to make sure they are secure.. also.. look at the pump assemby to make sure it isn't the source of the leak..then if nothing is obvious,, watch for leaks by using a flashlight and examining everything you can while it fills the tub.. Leaks are normally the easiest thiong to zero in on.. and ... try to have a few towels or wet/dry vac handy during all this.. Hope this helps...
Aug 30, 2008 | GE Washing Machines
GE Washer shaking
Check this first: level of machine and all feet secure. Is the machine on a pedestal and is it securely fastened? Are your clothes wet after a spin? I know I stress drain height and hose placement, but todays washers are power misers and this means smaller motors. A pump needs some give at the drain, a slight gap like an old dishwasher so it can pump easier. I feel some water is in the machine and not draining in time causing a vib during spin.
Jul 11, 2008 | GE WBVH6240F Front Load Washer
GE WBSR3140DW Top Load Washer Logo
125 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
