Question about Dometic Rooftop RV Air Conditioner
Air conditioner circuit tripping - Dometic Rooftop RV Air Conditioner
  • 49 Answers
Check the Compressor run capacitor. it is swollen or leaking oil. it is the little silver canister in the controls box or uner the hood on top of the unit. The is the most propble cause other than a bad compressor.
Posted on Oct 13, 2010
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
Could this keep the air conditioner running and trip the breaker
Air conditioner may draw high current. It may trip the cirucuit breaker. You may check the current rating of the air conditioner. If it is higher than the circuit breaker rating, it surely will trip. If it is close but lower, it may trip as there may be other appliances connected.
Sep 27, 2015 | Heating & Cooling
What causes caravan aircon to trip circuit breaker on start up
My first guess would be that the compressor has seized. If not the compressor seizing, then I would look for a short to ground in the wiring. If you pull the cover of the AC you will most likely find that the compressor motor is plugged into a receptacle. If you can unplug or otherwise disconnect the compressor motor from its' power source and activate the thermostat to run and the circuit breaker does not trip, it is the compressor motor. If the circuit breaker trips, then it's in the wiring.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
I have a Quick Cool (59516.501) which just started tripping the 20 A circuit breaker. I replaced the circuit breaker. Unit still trips the circuit breaker.
you will need to access the unit and look for burnt/shorted wires on/at compressor. if not then the compressor is locked down/shorted and will need replaced Tim
May 29, 2011 | Dometic Rooftop RV Air Conditioner
Tripped off
If circuit breaker tripped off for second times do not re-set the circuit breaker and switch ON. Theres might be short circuited in the source line of your ac. Also check the status of compressor, windings might insulation failure, capacitor or fan motor short circuited or grounded. If you don't know how to do this, pls. call qualified technician.
Jul 06, 2010 | Carrier 36KCARMS Air Conditioner
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
Aug 09, 2009 | Dometic 57915531 Air Conditioner
Air conditions trips circuit, wont stay running.
Is it a window unit?
Did you check that the condensor coil is free of dirt?
Is the Fan motor running or does it stop before the breaker blows?
Jul 29, 2009 | Kenmore 75085 Air Conditioner
Circuit board fuse tripping in cool position
it could be short circuited compressor contactor coil
May 28, 2009 | Goodman CKL42AR42 Air Conditioner
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
