Question about Kenmore 44102 Front Load Washer
Washer has stopped, flashing F-24? What do I do, can not find my owners manual. Thanks
  • 15,935 Answers
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F24” Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Front load washer displays f 24
Here is a link to the owner's manual for that device.
http://www.searspartsdirect.com/partsdirect/user-manuals/mhwz600tw01-maytag-residential+washer-manual
Mar 19, 2014 | Washing Machines
I am getting a flashing signal on the timer display that says f11. The washer stops filling and I have to cancel the cycle. The owners manual says that this is an electrical problem I have cycled the...
The owner's manual is not very clear in its explanation! When it refers to 'electrical' problem it really means that the problem is not to do with anything mechanical (water, motor, door not locked etc) rather than 'electrical' being the actual power/ breaker supply.
Whirlpool's 'F11' refers to 'communications error, control unit'- 'electronic' would be a better description. Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I can't find my owner's manual and my Kenmore front load washer is stopping in the middle of the wash cycle and flashing F-30. Don't know what to do. The washer is one year old.
First, see the following Sears Parts site.
Enter your model number (###.#######) and you should see a list of sub-components.
On many washers, to the right of the components is a place where you can click and see PDF versions of the owners manuals.
If the Sears site doesn't have your owners manual, you may try looking at the following Whirlpool maintenance manual for front load washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/07e2c9ebdcf04a3085256f38004f9b84/$FILE/WPWASHER1.pdf
Oct 18, 2009 | Kenmore Washing Machines
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Kenmore front load washer HE
could possibly be the heater element failed check it with an ohmmeter should read below 30 ohms if there is no reading then it is open circuit and needs replacing
May 18, 2008 | Kenmore 46462 Front Load Washer
Kenmore he3t front load washer time flashing stuck
Take the front panel off your washer. Inside the washer attached to the side you should find a manual that will help you with the error codes.
Aug 30, 2007 | Kenmore Elite 45986 Front Load Washer
Flashing F4 on control panel
According to the Owner's Manual Troubleshooting section: "Press STOP/CANCEL twice. Open and close washer lid. Reset cycle and press START. If problem persists, press STOP/CANCEL twice to clear the display. Call for service."
Aug 05, 2006 | Kenmore 23822 Top Load Washer
Kenmore 44102 Front Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
