Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
Press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Posted on Sep 15, 2010
  • Mark Oct 11, 2012
    Tried that on mine, it was blinking as well. Pressing off button had no effect.
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Washer won´t start, not all leds light on and when i press the start bottn, it just won´t start
Hiya,
Machines not starting are often due to the water not getting through 1st check would be to make sure the hoses are connected correctly & that the water taps to the machine are switched on this is a common problem when an apliance has been moved for either cleaning or re-instalation after a move, if it is the taps not switched on the macine will start working again straight away if it's not the taps then it could be the pump.
Hope this helps
Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Blinking "Normal" button
PROBLEM: STOPPED RUNNING, WILL NOT START AND
CLEAN LED BLINKS 7 TIMES, THEN REPEATS
(WATER HEATING FAULT)
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
Wash pump not pumping water
past the heater efficiently.
See “WASH PUMP WILL NOT
PUMP”.
Door switch not making
contact consistently:
■ Faulty or sloppy door latch
assembly (which can be
aggravated by high door
closure force keeping strike
plate from fully seating).
■ Faulty door switch (high
resistance).
NOTE: Neutral switch on
plastic tub models is only in
series with motor and heater;
other loads are not affected.
1. Unplug dishwasher or disconnect
power.
2. Measure resistance of door
switch contacts while checking
mechanical operation of latch
assembly. Confirm switches not
loose from assembly. Check strike
plate and door closure.
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Sep 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
926 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
