Question about NEC NP60 Projector
Vertical lines are being displayed on a smart board installation. Any suggestions
How to remove vertical lines on my 50" devant smart tv
suggestion look some youtube examples red lines or missing parts are very different or fcc sheets or connectors or faulty t-com boards its only to find on suggestion where are vertical line problems it can also be on the signal of a shifted free channel by the provider ? several posibilities.
https://www.youtube.com/watch?v=LysMj2Tcp4M
Jun 05, 2017 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Thin black/transparent vertical lines across the screen
If the lines aren't appear at least in one input or in smart apps then theres no posibility that the time-control is malfunctioning.the more logical is mainboard is isn't working right . could you provide me with more info and maybe a photo i'm sure I can get you a better and more advanced answer to that
Jun 23, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
NEC NP60 Projector Logo
616 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
