Question about Kenmore Dryers
I have a Kenmore Electric Dryer Model# 110.96551220. When i push the strat button, the dryer does not start but I hear a surging type noise. Any idea what is wrong?
    President:
  • 3,074 Answers
You will need to remove the front panel, unplug dryer, open dyer door remove screws from inside the door frame, with a flat tip screw driver gently pry up as it is clipped and it will pop up, you will need to disconnect the door switch and sit the front panel aside. The top of the dry will lift up, on the motor look for two switches.buttons one is a reset the other is a trip. you will hear a click when you reset it. hopefully this is the problem, if not then see if you can turn the drum, it should be hard to turn but turn all the same. Hope this helps tim
Posted on Sep 11, 2010
Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Nov 02, 2009 | Kenmore 62602 Electric Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Kenmore 80 Series dryer won't start.
i see this all the time the dryer motor is simply to weak to kick in so it humms or sometime starts,a good test to do is flip the top up and push the start button and turn the drum at the same time and the motor should kick in,the dryer has no ball bearing it is on rollers,if you want you can check your local used appliance store and see if they have one or maybe ebay,your model number is inside the dryer door,so to sum it up it is the motor,let me know how you make out-mike
Apr 13, 2009 | Kenmore 62882 Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Jan 05, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
119 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
