Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I have a gas dryer that doesn't heat. The falme comes on last for about 10 secs then cuts off. I have replaced both coils and high limit thermostat.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Tip
Whirlpool Dryer Various Test Procedures - Part 2
TEST #4 Heater
This test is performed when either of the following situations occur: Dryer does not heat Heat will not shut off
This test checks the components making up the heating circuit. The following items are part of this system:
Harness/connection, Heater relay, Thermal cut-off, Thermal fuse, High limit thermostat, Gas burner assembly,
Centrifugal switch, Exhaust thermistor, Machine control electronics, Gas supply. Dryer does not heat:
1. Unplug dryer or disconnect power.
2. Remove the back panel to access the thermal components.
3. Perform TEST #4b. If the thermal fuse is OK, go to step 4.
4. Perform TEST #4c. If the thermal cut-off is OK, go to step 5.
5. Locate the high limit thermostat. Measure the continuity through it by connecting the meter probes on the
red wire and blue wire terminals. If there is an open circuit, replace the high limit thermostat and thermal cutoff.
Otherwise, go to step 6.
6. Perform TEST #4d. If this is OK, replace the machine control electronics.
Heat will not shut off:
2. Access the machine control electronics, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (red-white wire) at the connector. If 5–15 k ohms are measured, replace the machine control electronics. If the resistance is greater than 20 k ohms, replace the exhaust thermistor.
TEST #4a Exhaust Thermistor
The machine control electronics monitors the exhaust temperature using the exhaust thermistor, and cycles the heater relay on and off to maintain the desired temperature. Begin with an empty dryer and a clean lint screen.
1. Plug in dryer or reconnect power.
2. Start the Timed Dry cycle.
3. If after 60 seconds, F-22 or F-23 flashes in the display and the dryer shuts off, the thermistor or wire harness is either open or shorted. Unplug dryer or disconnect power. Check wire connections at the machine control electronics and thermistor. If wire connections are OK, check exhaust thermistor resistance per step 5.
4. If F-22 or F-23 does not flash in the display, the connections to the thermistor are good. Therefore, check the exhaust temperature value at any or all of the temperature levels in question, using the Timed Dry cycle, and the following process: Hold a glass bulb thermometer capable of reading from 90° to 180°F (32° to 82°C)
in the center of the exhaust outlet. The correct exhaust temperatures are as follows:
TEMP
SETTING HEAT TURNS
OFF* HEAT TURNS
ON High 155° ± 5°F
(68°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Medium 140° ± 5°F
(60°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Low 125° ± 5°F
(52°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Extra Low 105° ± 5°F
(41°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature The measured overshoot using the glass
bulb thermometer in the exhaust outlet can
be 30°F (17°C) higher.
5. If the exhaust temperature is not within specified limits, or you have come here from step 3, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (redwhite wire) at the connector. If the resistance is OK, check P14-3 and P14-6 to machine ground. If resistance is greater than 0 (zero), replace wiring harness. NOTE: All thermistor resistance measurements must be made while dryer is
disconnected from power. The following table gives temperatures and ranges for the associated thermistor resistance values.
Temp
F C
Res
kΩ
Temp
F C
Res
kΩ
50° (10°) 19.0 -22.0 80° (27°) 8.5-10.5 60° (16°) 14.8-16.8 90° (32°) 6.8-8.8 70° (21°) 11.5-13.5 100° (38°) 5.0-7.0 If the thermistor resistance does not agree with table, replace the exhaust thermistor. If the thermistor resistance checks agree with the measurements in the table, replace the machine control electronics.
TEST #4b Thermal Fuse
The thermal fuse is wired in series with the dryer drive motor.
2. Access the thermal fuse by first removing the back panel.
3. Using an ohmmeter, check the continuity across the thermal fuse. If the ohmmeter indicates an open circuit,
replace the failed thermal fuse.
TEST #4c Thermal Cut-Off
If the dryer does not produce heat, check the status of the thermal cut-off.
2. Access the thermal cut-off by first removing the back panel. .
3. Using an ohmmeter, check the continuity across the thermal cut-off. If the ohmmeter indicates an open circuit,
replace the failed thermal cut-off and high limit thermostat. In addition, check for blocked or improper exhaust
system.
TEST #4d Gas Valve
2. Access the gas valve by removing the front panel and drum assembly.
3. Use an ohmmeter to determine if a gas valve coil has failed. Remove harness plugs. Measure resistance across terminals.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
My gas dryer model # lgr3624eq1 coils are lighting up and igniting for approx 10-15 seconds. after that the coils will only light up for 10 sec. and dim down without igniting. from this point it continues...
check the thermostats they look like this http://www.partselect.com/assets/repair/images/Dryer_thermostat.jpg Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature. if that doesn't work, or the thermostats check out to be fine, replace the coils on the gas valve itself, you can see them here http://www.google.com/products/catalog?q=gas+valve+coils&um=1&ie=UTF-8&tbm=shop&cid=4089675631004876356&sa=X&ei=T-kQTsTCF4SmsQOlssWuDg&ved=0CC0Q8wIwAQ
Jul 03, 2011 | Whirlpool Gas Dryer Flame Sensor 338906
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The
Jan 19, 2011 | Roper Dryers
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Nov 08, 2010 | Kenmore 72822Gas Dryer
For whirlpool duet GGW 9250 PW0 GAS DRYER How do you know if the gas solenoid are bad? I check the resistance as per manual and its within its limit. It ignites and flames come out but the flame only...
The gas valve solenoid coils work when cool that's why the resistance reading is within the limit but fail when heated. Bypass the thermostat on the burner funnel and if the flame still goes out too soon, the coils are weak and both must be replaced. The resistance reading is reliable only when the dryer does not heat at all or shall we say the flame does not go on at all and the purpose is to check the continuity of the coil.
Oct 12, 2010 | Dryers
Maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Apr 28, 2009 | Maytag Neptune MDG9700A Gas Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
