Question about Sansui VRDVD4005 DVD Player/VCR
No disk When I insert a dvd it tries to read and then says no disk. My same unit began getting fussy re: disc loading. It would randomly post a C-104 code...suggesting the disc is dirty/scratched. I cleaned the laser head...but to no avail. Some days, I could put a disc in, other days...not. Finally the unit went to the no disc mode...and remains there. Shutting down/cutting power for 24 hrs. doesn't work. Any ideas?
    Guru:
  • 1,894 Answers
I think ur lens has totally gone dead..
u will have to replace the lens..
Posted on May 15, 2008
    Genius:
  • 3,422 Answers
HI,
I hope this will help ya..
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 14, 2008
  • 796 Answers
May be the laser head in your player is not moving properly and detecting the cd/dvd properly....
have you tried with clean dvd`s
  • Sansui Master
  • 13,433 Answers
The lens is most likely faulty the whole lens system would need to be replaced. Not that big of a part but still it can be a little complex repair job.
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
On searching this problem it seems its quite popular unfortunately. All i can suggest is trying to laster cleaning again in vain that it will make the device play again..
Please see http://www.fixya.com/support/p17041-sansui_vrdvd4005_dvd_player_vcr_combo
and you will see all the users with similar problem.
Sorry i cannot help more but it sounds like you need a new player.
Hope this helps.
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Insert disc.....
May be looking for a firmware update disk. Try looking on the panasonic website for firmware updates for this unit. Burn the file to a disk and put it in the machine and let it load.
May 29, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
When I insert a disc I get a "Disc Error" after
Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
Jun 14, 2011 | LG DP450 Portable DVDDivX Player
When I load a disk I get 'Read', then 'No disk'. I have tried several commercial disks, and have tried with each side up. I have looked into the disk slot and cannot see anything which might have been...
If u can't play many of the DVD discs from Hollywood movies,Useally the disc itself the problems or the DVD recorder laser eye it bad.Tries websites like Amazon.com,Ebay.com buy a DVD cleaning kit.Put the disc in follow the directions,clean the laser eye data reader.50/50 chances will solved the disc not reading problems.If not the Laser eye is problems the unit not worth fixing buy a new one.DVD players are not woth the fixing of the Tech. prices.
Dec 15, 2010 | Panasonic DMR-E30 DVD Recorder
Dvd player says no disk when inserted even after cleaning
Hi, the optical unit in your combo needs to be replaced, unless the cleaning disk has not been tried enough. Perhaps it's time to have it cleaned professionally. Try the cleaning disc several times and see if you are able to get the disc to load, one idea for you, try an audio disc and see if it reads it(loads it) if it does play it then for sure you have to replace the optical(the dvd side of the unit is inefficient).
Nov 17, 2010 | TruTech T2000D TV
What is error code ox4001100200001005 on an HP entertainment latop pc I get this when I am trying to recover from either the CD or HDD. Thanks
Try cleaning the CD DVD drive and insert the restoration disk.
Restart the unit with the disk inserted.
If the disk is un-readable, it will not restore.
Oct 01, 2009 | HP Pavilion dv6000z Notebook
Dvd not playing
Welcome to Fixya! Have you tried the Cleaning Disk that you can get at Most Radio Shacks???? Works really good on mine whenever it does this!
Jan 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Sansui VRDVD4005 DVD Player/VCR Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
