Question about KitchenAid 32685 Mixer
While making dough, the part bearing the motor has started rocking up and down. Hard to say as to which portion is loosening out. Please let me know whom to contact. Thanking, Ramesh Bharadwaj Oceanside, CA 92056
  • 857 Answers
You can directly call Kitchen aid on these nos:
1-800-541-6390
or
1-888-886-8318
or contact a local technician.
Posted on Sep 12, 2010
A Hobart A200 stand mixer that I cannot get the dough hook off of?
Try and get some CRC into the top where the hook joins the shaft. You need to be rocking it back & forth to try and get movement. Gradually the movement will increase if your strong men are strong enough and have stamina as well. Once you get it off clean up the shaft with a wire brush. Clean out the hole in the dough hook with the proper size drill, you don't want to make the hole bigger, just cleaner. It will be a build up of flour in there, it packs hard and shrinks the hole, almost unbelievable but true.
Aug 04, 2015 | Hobart A200 Stand Mixer
The mixer makes noise at stir speed. If I press down on the black contact plate at the rear of the mixer, the grinding goes away. I am not sure if it is the rear motor bearing or something else.
Hi,motor bearing usually worn out if you dont put grease on it.try also to check screws it might loosen up.Bearing might as well not contacted with the upper surface does it makes noise.Screw and bolts might as well loosen .Hope this helps.
Jun 21, 2011 | KitchenAid K45SS Classic Stand Mixer
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
I have a 275W Classic Plus, about 5 years old. I've never done any maintenance on it. It gets used several times per week for the basics (banana bread/cake batter, cookie dough) and also at least once a...
There are lots of places to be looking, first thing I would look at would be under the rear cover to make sure the two nuts that hold the rear motor bearing housing in place are nipped up. You don't wring the neck on these nuts, if you over tighten them you will deform the rear bearing housing.
If you can find someone local who has been doing these mixers for a while they will be able to give it a once over. It's unlikely to be expensive. Best people to ask is Kitchen Aid, they should know who does their warranty work in your area. If you are in new Zealand it will be me.
Jun 30, 2017 | KitchenAid K45SS Classic Stand Mixer
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
KSM5PS won't turn under load
Hi. Remove the top cover and look for the plastic transmission housing, it's toward the front of the machine. Look for cracks in this housing. If the housing is cracked, remove it and look for further damage to the worm gear assembly and the bearings and bearing seats that support them. You'll have to remove some of the grease to inspect the parts. If you're lucky, only the trans. housing will need replacement. If, like me, you're not so lucky, you may have to replace the housing, wormgear assembly, bearings and re-work the bearing seats so that the new bearings fit properly. Although Kitchenaid advertises that their mixers can easily handle bread dough, the truth is...They can't. This scenario happened to me and I had to replace all of the above. Be prepared to wait a month or more before your parts arrive. Specify that you want the METAL trans. housing. I'm still waiting (6 wks.), for a single bearing. If this solution works for you, please rate my solution. Good Luck! ricardok45
Nov 14, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My mixer started to smoke!!
The gearbox grease has separated and is starting to move (slowly) onto the motor armature area through the front bearing. Replace the grease and since it will be apart, use a lot of cloth strips (NO Q-TIPS! TOO STRINGY - LEAVES A MESS) and alcohol to clean off the motor's armature, housing area and any place you see grease slung around. It's not going to be easy, but worth it. I will try to post pictures as I am doing this right now 12/28/17 to my wife's Kitchenaid for this exact reason.The first image is the gear side of the motor bearing, where the thinning grease is moving through. The second image is a shot of the armature of the motor where the brushes touch and will smoke if grease gets that far (it does). The third image is a cleaned out armature area (brushes removed and speed switch moved)The last is the pooled oil separated and sitting just behind the gear box (where will it go if you tilt the head back?)07667273-29b4-4c89-b9b3-12896c8ef14c.jpg20171228_163751-wafg2nvpw021bpnzetjjpo05-2-2.jpg20171228_165900-wafg2nvpw021bpnzetjjpo05-2-3.jpg20171228_173846-wafg2nvpw021bpnzetjjpo05-2-4.jpg
Aug 17, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid 32685 Mixer Logo
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
