Question about Refrigerators
We have a LG fridge, about 5 years old. Recently we noticed small puddles of water on the floor underneath. When we pulled it out we discovered this is the result of frost build up on 2 of the copper coils in the bottom back of the fridge melting periodically. We've cleaned the black coils and vacuumed everywhere but the cycle continues, frost=melt=puddle. There is no frost build up inside the freezer and it cools fine.
    President:
  • 3,773 Answers
Then freon needs to be checked by a service man
or compressor.
Posted on Sep 12, 2010
Water leakage out of fridge
it may drain hose is loose
Jun 04, 2010 | LG Refrigerators
Water leaking on the floor from fridge
That might be a leaky water valve connection Or it could be bad door gaskets.
Feb 15, 2010 | Refrigerators
I recently moved. After re-connecting my LG Fridge I noticed that you can hear the water run for several seconds before it starts to fill the glass with water. What could be the cause of this?
Usually a small leak in the water line from water valve to the water filter.
I have seen when moving a ref the movers catch the plastic water line on the back of the box on the home door to the outside and damage it.
Pull out the Ref. and inspect the tubing.
Be sure to protect your floor.
Jan 06, 2010 | LG LRSC21934 Side by Side Refrigerator
Dehumidifier leaking onto floor.
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Dehumidifiers
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Refrigerators Logo
243 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
