Question about Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62HM196. Original tv would not start up. Was indicated that is was the ballast. I purchased a used ballast and installed it. Now the TV begins to start up, the blue lamp on front turns on, the light begins to light for say about 10 seconds, slowly getting brighter, then tv shuts down before it is fully lit. The yellow lamp will on front of tv will then tend to blink 9 times after this may happen. Usually have to wait maybe 30 seconds or more before tv will try to power back on again. When I try the second time, it may begin to light but turn off much faster. I have seen the yellow lamp blink five times, and sometimes 9 times. I know on the third attempt to start the tv, the bulb lamp will not light, but attempts after it may begin to light. I don't know if it is the lamp, the ballast or the light engine. I never see the red light come on. I looked at other parts of the tv such as power board and visiblity they seem okay but not electrically tested. I am hoping someone can point me in the right direction and help eliminate what the problem may be. If someone knows the diode part numbers used on the ballast I could attempt to repair the original ballast as well. Thanks
  • 1 more comment
  • glabadie288 Sep 12, 2010
    Thanks, I will give the lamp a try.
    I was also looking at re-building the ballast I took out. I am fairly certain it is the diodes on the ballast board but haven't been able to identify what they are. A schematic was not provided with the service manual for the ballast. Specifically D4, D5, D2 and CR1
  • glabadie288 Sep 22, 2010
    I purchased a lamp, and the tv still will not start up. The symptoms are unchanged. I was wondering if there is a light sensor or something that has failed. Any other suggestions of where to look? I have the service manual and schematics.
  • glabadie288 Sep 23, 2010
    Yes, all the fans appear to be running
  • Toshiba Master
  • 5,138 Answers
Lamp needs to be replaced,
Mats has them for $99.00 1-800-628-1118
Posted on Sep 11, 2010
  • 3 more comments
  • ladywinn
    ladywinn Sep 13, 2010
    On the old ballast board resolder board and replace the Big Capacitor on board,then when you get new lamp see if it works.
    Your help is much appreciated. I changed the bulb, but the condition remains unchanged. Do you have other suggested tests to help determine why tv will not start?
  • ladywinn
    ladywinn Sep 22, 2010
    OK some of my buddies have had good results with resoldering Ballast board and replacing the Big Capacitor on board. When Set starts to turn on is all the Fans Running?
    Ballast Board PN# 75002847 Partstore.com had themyou can go to their website and you need to look on Ebay ,I got Ballast Board for my TV for $65.00 Look under Electronics/Parts
    type in Part number.
  • ladywinn
    Encompass Parts Distribution Might have Service Manual for this TV?
    1-800-638-3328
    Yes, All the fans are running.
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Toshiba 62HM196 "flickers"
You may have to wait for the problem to become more frequent to see what is wrong.
Mar 12, 2012 | Toshiba 62HM196 62 in SDTV DLP TV
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
Purchased a new bulb for our Samsung HL-T4675SX DLP TV in October. Less than 3 weeks after the bulb was installed, the TV would not turn on and the three indicator lights on the front of the TV came on,...
ballast failures are not that common in general. i would suspect the color wheel before the ballast. do you hear a whirring noise when the tv is trying to turn on. sometimes the color wheel will not spin correctly and the tv will not start as a result.
Dec 23, 2010 | Samsung HL-T4675S Television
I have the Toshiba 62HM196. When the input is cable it appears to have no red tones however when the input is antenna there is red. is this the TV or the cable box?
It the cable box or the incomming broadcasting coaxial pay cable connection.U try a antena getting a free DTV air broadcasting signal ur got red wright?So it not the tv.
Oct 13, 2010 | Toshiba 62HM196 62" SD Television
Toshiba 61 rear projection, im not sure what wrong with it. One day it decided it wont transmit any pictures. The standby light is on but no picture. At first i thought i may be the remote not working, ive...
When was this tv has it projection lamp last replaced?If 1 1/2 or 2 years.Tv on an used like 4 or 5 hours a day.The projection lamp life is over.Require change another projection lamp.U hear alot of clickings too?That mean the board call the Ballast board it also dead,and require changing too.This Ballast board,help to ignite the projection lamp.
Aug 14, 2010 | Toshiba 61H71 61" Rear Projection...
Will a light from a 62HM196 work on a 62hm15a
I looked up both models and both tv sets have different part numbers so probably not!
techman
May 04, 2010 | Toshiba 62HM15 62" Television
Need to install a replacemen lamp in a Toshiba 62" HD DLP Projection TX. How is it installed?
What is the model number??, There are just way too may Toshiba sets to try and guess the one you have!! or try here. http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TVom.asp
Good Luck
TECHMAN.
Sep 05, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
TV Stand for Toshiba 32HFX71
Amazon.
Toshiba TV Stand 62HM196
Jan 20, 2009 | Toshiba 32AF41 32" TV
Toshiba 62HMX84 62" Rear Projection HDTV Logo
562 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
