Question about Baby Trend FlexLoc Infant Car Seat Gabriella
We can not get the base tight to the seat. We have no more strap left after pulling up with our knee pressing down on the base.
A huge saver for me was placing a foam "Swim Noodle" under the base of the car seat to take up the slack so that you have a tight and secure fit of the base in your car. You can easily cut one to size. One thing they don't tell you is that not all car seats are a good fit for all car models. If you do not have any foam noodles a rolled up bath towel may do the trick as well. I have tried both of these methods upon the suggestion of our local police department that helped me when my son was an infant. Good Luck.
Posted on Sep 11, 2010
Favorite thing dropped into the seat belt cavity in the back seat of a 2006 Lexus LS430. Any good ideas? Through the trunk or how do we remove the back seat?
Pop the rear seat base out. Just push against the seat base bottom on the sides of front of seat bottom with your knee and pull up with your fingers. Seat base will come up no problem. Retrieve your "favorite" thing and put the base back in, hold it down with your hands while pushing it towards the rear with your knee and it will pop over the holding clips. Ya got your piece back and no harm done.
Jul 20, 2017 | Lexus Cars & Trucks
How to fold down rear seat on Porsche Cayenne
Remove headrest, there is a small button on the base of the headrest mount you need to push in. Next pull up the strap at the front of the seat cushion bottom, then flip forward. Press in the flipper on the top of the seat back and pull forward.
Sep 06, 2014 | 2009 Porsche Cayenne
I have a turn a tot car seat and the straps that hold her into the seat are to long and i can't work out how to shorten them and i can't find instructions anywhere
I guess you have pulled the harness adjuster strap tight (between the legs on the front edge of the seat) and are still left with slack shoulder harness straps. It may mean you need to remove the seat and check the harness straps are going thru the shoulder slots in the seat, then they need to go up and over the the metal shoulder rod before going down to connect onto the metal spreader plate
Dec 13, 2009 | Baby Gear
Trouble removing snugride base from car
If the base was installed by someone who put their body weight on it to get it really tight, try to do the following:
If you are able, climb in the car and place your knee in the center of the seat base and put your weight onto it. Then, at the same time, try to pinch the clip end of the latch belt (the strap part that is attached to the car seat base) and push the clip away from you (toward the seat) to remove it from the metal latch loop/ring (the part of the latch system that's actually part of your car).
If this doesn't work, you can try to loosen the strap a little while leaning on the base, and then try to push the clip forward and out of the latch ring.
Aug 06, 2009 | Graco SnugRide - Giselle Infant Car Seat
How do you fold the back seat down on a 95 Isuzu Rodeo 2wd
Here is how I fold down the back seat of my 1995 Rodeo. First thing I do is remove the headrests on the back seat. Then I place my knees (and all my weight) on the middle of the seat (bench), and pull on both belts straps. If this is done properly, I will hear each strap release. (sort of a click). As soon as I hear it release, I stand up as best I can while at the same time pulling up the seat. I then manage to step out of the Rodeo while letting the seat fall forward. After that, I am able to drop the other part of the seat into the forward position.
Jul 04, 2009 | 1995 Isuzu Rodeo
I have no idea how to get the stupid straps back in. Can I get some dang directions?
My daughter has a car seat just like this one, and I wash it about once a month so I hope I can explain this detailed. First, at the base there is a metal rod that will need removed. When you take this rod out the base and seat will seperate. Set base aside and turn seat upside down. Take your strap and put an end into each slot. Turn seat over and pull your straps even. Put the two black pieces for your latch on (one on each side) then put you chest pieces on and run straps thru slots on back of seat. Turn seat around and make sure the straps go OVER the silver bar in back (this allows you to adjust shoulder height) Secure to the metal piece that runs to front for tightening adjustment. Set seat back on base and replace rod. Hope this was helpful.
May 13, 2009 | Eddie Bauer Deluxe High Back Booster...
Rear facing latch problem
I had trouble getting mine tight too and my sister said what she did was kneel in the seat and then pull up on the strap. I tried that and it worked! I think it pushes the seat down more so that you have more strap to pull.
Sep 16, 2008 | Eddie Bauer 3-In-1 with Latch
Uninstall snugride base
The straps should have a release buckle, just pull it really hard while the carseat is removed. Its a lot easier if you put all your weight on the base like kneeling down on it while pushing the release buckle toward the crease of the seat and alternating weight on the base. Good Luck, and remember, you can always cut and replace the belt if necessary!!:)
Aug 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
Help
need to adjust straps
Feb 12, 2008 | Evenflo Cozy Carry 5
Installing into a Honda Passport
If this seat has the areas for a regular seat belt to go thru, you could use that belt to install it. Every seat belt if you pull it out all the way, and then start retracting it, it because super tight and cannot be pulled out again, until its been retracted in almost all the way. Be sure when doing this you get the seat belt as tight as possible. I like to put my knee into the car seat and press as hard as I can as I pull on the seat belt to tighten it.
Apr 09, 2007 | Cosco Summit High Back 22-260
Baby Trend FlexLoc Infant Car Seat  Gabriella Logo
366 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Scott Jelt
Scott Jelt
Mike
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
