Question about Fujitsu Siemens AMILO Pro V2010 Notebook
The display of screen is not clear.The graphics are low
    Problem Solver:
  • 13 Answers
Make sure all drivers are installed, chipset, graphics drivers, go on to the fujitsu siemens site to download them
Posted on Sep 12, 2010
How to fix it,it has problem with display
check your signal cable, try to clean connections on the ends of cable, are you using any adaptors to connect the screen, maybe the adaptors arent working correctly. Is or was your GPU overclocked?. There could be many reasons, but start with the simplest and work your way thru.
Apr 18, 2015 | System Integration Business ATI RADEON...
Card didn't work while fan is running
That is a really low end video card. The same card is available for $10-30 on bidding sites. Get another one or upgrade to something with more horsepower if you like games or watch video. Just make sure your motherboard will support the new video card. THe one you looks to be a standard PCI (older format).
Mar 08, 2014 | Nvidia GeForce FX 5500 Video Card Graphic...
My laptop lg x130 stuck for almost a month when i turn on it the screen has no display
The display of your laptop is one of its most integral components, and if it is exhibiting problems, it is one of the most frustrating issues you can experience as a computer owner. A display can experience a variety of issues, from the mildly annoying flickering of a screen, to it not powering on at all. Identifying the problem is the first step towards assessing whether it can be fixed, or if it is time to get a new computer.
  1. Brightness
    • If the brightness of your screen is intermittent, or is flickering, it is likely that the inverter is broken. The inverter is a small board that controls the brightness of your screen. It plugs into the display and the motherboard, or the main brain of your computer. Try a new inverter board, which you can get from your computer manufacturer, or from a computer supply store, by taking out the inverter from your display casing.
    Garbled Video
    • If there is garbled video on your screen, it may mean that the low-voltage differential signaling cable, also called an LVDS cable, has begun to malfunction, or that the graphics card is failing. To check your LVDS cable, open up the computer and unplug the LVDS, which will be running from the motherboard up into your display. Plug the LVDS cable back in and with the computer open, turn the computer on and check the graphics. If it continues, you may need to take the display out of its casing and unplug the LVDS from the back of the screen. If the graphics issue continues, try another graphics card. If the new graphics card is in, and there are still graphics issues, the LVDS will need to be replaced.
    No Video
    • If there is no video on the screen of your laptop, it can mean one of two problems: that the display has completely given out, or the logic board is not supplying any video to the screen. If there is no video, try moving the screen forward to back several times to see if video appears momentarily. If so, there may be a loose connection. If no video comes on, hook up an external monitor to the computer and see if any video appears. If video does appear, it is likely the screen has died. If there is no video, your graphics card has failed. Depending on the logic board holding the graphics card, you will either have to replace the graphics card, or the whole logic board.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | LG Computers & Internet
My picture has been pixelated
Probably a bad display driver ( download the latest driver for video chip from the website)
Or might be the resolution is set too low ( right click on desktop / personalise / display settings and change) For XP, its changeable in the control panel / display box.
Test the laptop by connecting it to an external monitor, see if you get the same problem (if you do, see below re: graphics chip, if not, see below re: screen
After that, this could be faulty hardware, overheating graphics chips will cause the display to do this, best solution here, dismantle and clean the heatsink and fan, remove any dust build up.
If that still fails to work, the chip may be damaged beyond repair (new motherboard / graphics board depending on the laptop you have), Or, the screen itself may be failing (replace screen)
Jul 03, 2011 | Computers & Internet
My latitude D620 screen display is split in two sections help
This is not clear enough either you set up dual screen mode or your screen broke and displaying a line across the screen which most likely either bad cable connection or something broken. If it is a dual screen mode than you have to right click on desk top and go to properties and modify it to single screen.
Mar 03, 2011 | Dell Computers & Internet
I have Acer Aspire 5580. I am facing problem with the graphic, it is showing lines and color patches. When i am extending the monitor to external display, the external monitor is showing nice graphics. I...
if you changed the screens to a working one, then you should have a clear image on the main screen, or its damaged, or one of the monitor ribbons is not seated properly. have you updated your graphics driver?
Sep 19, 2017 | Acer Aspire 5580 Notebook
Screen resolution not changing even i changed it in the display properties. it is remaining same.When i was starting my desktop it is saying that your screen resolution is too low and colour depth is too...
Hello Friend,
Please visit below URl and download display drivers from "Video" section. If your computer having intel graphic card then please download intel driver or if your computer is having ATI graphic card then please download ATI driver
After downloading the driver install and reboot your system once.
This might fix your resolution problem.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Thanks & Regards,
Viju
Apr 03, 2010 | Dell OptiPlex GX260 PC Desktop
Wrong display on boot up.
Is the post/splash screen clear on initial boot up? Can you see the post information clearly?
Sep 29, 2009 | Intel D865GVHZ Motherboard
Screen turns black
Consider up gradeing your Power Supply Unit.,Depending upon a low wattage PSU to power significant upgrades ie;High end Graphics Processor Units,is a sure way to a black screen.Check out Power & Cool.com.
Mar 20, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Graphic / visual problem
do the DIRECT X latest version that support ur operating system... first u check that ur display driver installed or not..that is in device manager...then check display settings in control panel...if these two r ok,then do the direct x...
Dec 01, 2007 | Acer TravelMate 2300 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
176 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
