Question about Fusion EN-AT1100 300W Bass Reflex Tube with 25 cm Subwoofer Car Speaker
I can't connect power to it, how do I connect red cable from battery since it's just bare on the other end. There doesn't seem to be a place to slot it in on the sub
How to install a throttle cable model 3120xp
Instructions
1 Push the end of the new throttle cable onto the linkage on the carburetor, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
2 Place the throttle cable clip over the linkage. You may need to pry the end up with a flat-head screwdriver to get it in place.
3 Secure the throttle cable in the throttle cable bracket located on the intake manifold. This, too, should clip into place.
4 Route the cable into the cab, being sure to keep it kink-free.
5 Loop the end onto the end of the accelerator pedal inside of the linkage hole. In other vehicles, there may be a clip on the accelerator pedal that holds the throttle cable in place, which is also easy to do with your bare hands.
Jun 24, 2014 | Husqvarna Garden
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
Installing engine control cable
Push the end of the new throttle cable onto the linkage on the carburetor. In our C10 example, this is held in place with a clip, but on some other vehicles, the end of the throttle cable is capped and simply slides through a slot on the linkage.
Mustang Parts.
May 28, 2012 | Briggs & Stratton Garden
I have Acer Laptop with a JV50PU motherboard which has a faulty DC input socket connection. The laptop works OK on Charged battery but not on DC input. Is it possible to get a schematic of the motherb
If the DC Power Jack is soldered onto the motherboard then take the time to unsolder it and remove it. Then buy another DC Power Jack which costs less than $8.00 and solder it into it's place. Normally when it is soldered onto the motherboard there is no cable involved. That's all there is to it if it's soldered onto the motherboard.
If it sits on a slot in the motherboard and has a cable harness attached to it then you can purchase that too for less than $15.00. All you do then is follow where the other end of the cable harness plugs into the motherboard and unplug it. Then place the new dc jack in the slot where the old one sat and plug the other end of the cable harness into the motherboard.
Mar 20, 2012 | Computers & Internet
Jumpstart 1995 oldsmobile aurora
I'm not sure if the Aurora is a special type of car that requires a different way of jumping, but when u jump start most cars, you place the red end of the jumper cables on the positive/ red side of the battery and the black end on the negative. You want to make sure the jumper clamps are touching the metal part of the battery post (so if there's covers on the battery posts, move them so the cables have good connection. The same procedure is used on both cars. Be careful not to touch the end of the cables together, as doing so will make them spark if one end is connected to the running vehicle. Let your car charge a minute then try to start. If it starts, let it charge for 5-10 minutes and run/ drive your car after disconnecting to make sure the battery does not die the next time you shut it off. If it does not start after a few minutes of charging, adjust the clamps to make sure they have a good connection, wait 2-5 minutes longer & try to start your car again. *It is normal to hear the car that is jumping you idle more quietly when your car starts pulling juice from the charged battery. Also, remove jumper cables after charging, making sure not to touch the ends togther- as it will spark again. *it is not necessary to shut off the car that's jumping you before attatching the cables, or after charging. If your car still doesn't start after repeatedly adjusting cables and trying other cables to see if it is the cables not working, you may need a new battery or alternator. I would have the battery tested to see if you need a new battery before considerring the altinator.
Dec 23, 2011 | 1995 Oldsmobile Aurora
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
How to remove touchpad for cleaning gateway ID58 notebook Windows 7 i have all screws off back, removed battery and hard drive, silver strips on side seem to be the next step
Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
Slide the battery lock over to the side to pop the battery out from its compartment.
Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5
Remove the two screws securing the bezel in place from the back of the laptop.
6
Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor.
7
Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8
Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9
Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10
Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11
Pull the top cover up from the base of the laptop, removing the touchpad along with it.
Regards,
Ron
Mar 04, 2011 | Gateway ID5815H-CA LX.WC502.003 Notebook
Turn the key, heard starter solenoid pop, clicking like there wasnt enough power from battery. Replaced battery, turned key, and all the lights on dash went out, unhooked battery checked connection, then...
Either the cable from the battery to the starter is shorted or the starter motor itself has a dead short or the starter relay has a short. As soon as the key is turned, the starter relay is closing and all the power of the battery is heading for the short to ground. That's why the power seems to be lost.
Feb 09, 2011 | 1993 Mitsubishi 3000GT
When key is turned starter clicks and will not turn over, new starter, soloniod, ignition relay, worked for a few days and today click again, also new battery, it can be push started and will run
Hello! Either the positive battery connection or the ground connection is resistive (dropping voltage across the cables)...The ground connection being most suspect...If you have a digital multimeter and a wee bit of experience using one these connections can be tested...Set the meter to the lowest dc voltage scale...Place the + probe of the meter on the center of the + battery terminal...The - probe on the other end of the cable at the starter...You must read less than .03 volts...Next, place + probe on the - battery post and the - probe on bare metal of the starter case...You must read less than .05 volts,,,If not the connections need to be removed and cleaned so bare metal touches bare metal...A quick test with meter set on the X10 ohm scale is to measure between the center of the - battery terminal to both chassis and engine block...Both should read a dead short ie...zero ohms...Guru...saailer
Dec 07, 2010 | 2001 Chrysler PT Cruiser
Power connection for L365 Fish finder
Fuses and Breakers
Attach the red or positive wire to a 5 amp circuit breaker. If the unit is connected directly to the boat’s battery, include a 2 amp in-line fuse. (In-line fuses are available at most marine supply stores.) The power cable includes a smaller "shield" wire. Connect this to a good ground.
Extending the Power Cable
If you need to extend the power wiring by more than 10 feet, use a larger wire size. This will allow the wires to deliver the correct voltage in spite of the longer wire distance. For runs of 20 to 35 feet, use #14 AWG cable. If you extend the power wiring, be sure all electrical connections are solid and durable. Soldering is the best way to make these connections. Insulate all connections using heat-shrink tubing or electrical tape. You may also use crimp connectors or a terminal strip, but be sure to use good-quality marine-grade parts.
Apr 15, 2008 | Computers & Internet
Fusion EN-AT1100 300W Bass Reflex Tube with 25 cm Subwoofer Car Speaker Logo
411 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
