Question about Miele CVA2660 Stainless Steel Coffee Maker
Miele cva620 coffee machine I attempted to descale but the machine is now locked in security system activated how do I remove this lock
  • 4 more comments
  • david789860 Sep 12, 2010
    miele cva620 built in coffee machine
    machine is locked with the message
    "security system deactivated"
    machine went to 0 coffee before descale
    machine is locked with the display
    I know I have to press buttons but in what order
    the message security system deactivated is displayed whatever the programme dial is selected this display cannot be removed unless a code is entered
    I have an up button a down button an enter button water button and steam button
  • david789860 Sep 13, 2010
    I can make the machine "security system activated" or "security system deactivated"as per your instruction but no other function will work
    The machine is due to descale and this is when the problem started
    I have had the machine for 5 years and have never had a problem descaling before
  • david789860 Sep 14, 2010
    machine needs a code to get out of "security system deactivated" it needs to be descaled but no buttons when pressed do anything
  • 6,993 Answers
Usually the machine is locked in order to ensure that it is not operated by children or persons who are not acquainted with the machine operation.
To unlock the machine; turn the selector clockwise to the "lock" position and this is what will display on the machine:
Press the up button until the following appears on the display: "The machine is now unlocked and ready to dispense"
In case you need the manual for this machine, you can get it from the below link: The manual is in pdf format and might take some time to load depending on your internet speed, so you have to be a bit patient till it finish loading, and you must have Adobe Acrobat Reader on your computer to view it.
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Good luck.
Posted on Sep 14, 2010
  • Miele Master
  • 1,711 Answers
Can you give some more details how this happent and also if you see any masage on the display. Also the condtion of the machine , how frequent you perform descale and if you had any other faults before
Posted on Sep 12, 2010
  • espressonist
    espressonist Sep 12, 2010
    You should turn the selector switch to the "LOCK" position
    Press the up arrow once and the press enter now the machine will be ready.
    Turn the selector to the program and by pressing the down arrow find the "DESCALING STANDBY"
    and the press ENTER to confirm, now you can proceed with manual descaling and it will finish it will be ready to use.
    For any reference we thing you should download the manual to the following link
    http://www.miele.co.uk/Resources/Operati...
    President:
  • 2,185 Answers
Turn your machine off and close the door.
Press , holding it down, press then let go of both.
Then press 3 times. On 3rd time, hold it until Service menu appears.
Select then press left arrow to turn from to .
Then press right arrow by This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in.
Make sure to turn your machine off/on again to get out of Service Menu.
  • 2,272 Answers
The coffee system must be descaled regularly. The appliance will display a reminder message to descale and will eventually lock if not descaled.
The display will show "Please descale the coffee system. Remaining number
Of servings: 50". This message will now appear after each preparation.
1) Tap OK to acknowledge this message.
If the counter has elapsed to 0, the appliance will be locked, and the
Display reads: Please descale.2) Tap OK to start the descaling cycle immediately.
Descaling takes about 20 minutes. If you want to continue at a later point in time, turn the unit off. The appliance can only be used again once descaling is performed.
The machine will automatically Switch to water container operation For descaling program.
Activating/Deactivating the System Lock
1) Select "Settings flag", confirm with OK.Use to select "Safety", confirm with OK.
2) Tap until "System lock" is highlighted, confirm with OK.
3) Use to select "On", confirm With OK.
As soon as the machine is turned off, it
Will lock and cannot be turned back on.
A closed padlock and a message
Will appear in the display, whenever a
Button is touched.
To deactivate the system lock, follow the same procedure as above, but select "Off"
Overriding the system lock
1) Press and hold OK for approx 3 seconds.
The machine is now temporarily
Unlocked and can be used to prepare Beverages. It will lock again as soon as it is turned off.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
  • raj somaiya
    raj somaiya Sep 13, 2010
    Did you tried Overriding the system lock
    Unlocked
    Keep updated with the results.Thanks.
  • Miele Master
  • 19,396 Answers
Hi.
This machine has a security system lock to prevent unintended Start Up.
The system is locked or unlocked accessing the machine menu.
The lock DOES NOT reset by disconnecting power, guessing is useless.
Follow the instructions below to unlock the machine. If this comment was useful, please do not forget to accept the solution.
miele cva620 coffee machine
Meile coffee machine locked in descale
once it is time to descale, you must complete. there is no way to bypass.
May 25, 2012 | Miele CVA2660 Stainless Steel Coffee Maker
Miele coffee machine cva 620 saying water system fault
Wow, I used a shop vac as someone else had posted. I realised that there are actually two valves where the water tank rests so I vaccuumed from the valve closest to me and a lot of water was sifoned out. Then my CVA620 coffee maker reset itself. Make sure you go through the coffee making process as the first coffee was not up to standard.
Apr 14, 2012 | Miele Coffee Makers & Espresso Machines
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
Jun 12, 2011 | Miele Coffee System
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
Need service manual, exploded view or part list
I just typed in your model of coffee machine in and there is a service manual in there on the web, it won't let me copy and paste but you can go there and print it out hope this will help you
May 30, 2009 | Miele CVA610
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Descaling, not reading program mode
turn to lock and hold ^ button for 10 sec to change security setting on or off. should be off . then switch to program mode and use up & down arrows to descale with * , hit enter turn on steam.
Jan 01, 2009 | Miele CVA615 Espresso Machine
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Descaling a Miele Coffee maker
Put them in the water chamber then they dissolve and you run they cycle. I would cycle through a second time also with water only to flush the system out.
hope that helps.
Jan 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA2660 Stainless Steel Coffee Maker Logo
1,181 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
