Question about Refrigerators
After appx 3 days it freezes up like the defrost function not working.. i opened the freezer panels and manually defrosted. and it accured again.. this time i checked the resistance of the heater and it was good.. it is a ge tbx24z series..any suggestions on the next parts to check... thanks
  • kevin butler Sep 12, 2010
    i did notice while the temp selector was in off position.. the front of refridge got hot... i take it it has a front heater... then turned on fridge and it did cycle off when got to right temp...listened real close and i could hear the timer working...i did not jump out thermostat on coil but did just order part due to fridge put back together...will let u know shortly....thanks
  • kevin butler Sep 16, 2010
    i tapped on the thermostat and unit is working properly it did defrost.. got new part in so installed... thanks for the help
  • 2,272 Answers
If the defrost cycle stoped working, your coil would load up with ice and your freezer would start getting warm. Once you have a blocked coil, you lost total cooling in your freezer.As you mentioned that the heater is checked ok.then also still if the heater is not getting that required heat then it will not start the defrosting procedure,There is a cycling thermostat connected directly to your evaporator coils (behind the back wall in your freezer) that will probably need to be replaced.part number is PS303547 and can be ordered at partselect.com. Cost is about $10.------------ Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 11, 2010
  • raj somaiya
    raj somaiya Sep 12, 2010
    Yes keep updated.
Refrigerator make and model - GE TFG27PFX[A] Refrigerator side is ok freezer does not freeze as it should. display indicated PF. on inspection i found the bottom cooling coil frosted , but nothing...
This model is an older unit, so when you stated frost how much? Is the fan running in the freezer? If you have a-lot of frost in the freezer you could have a defrost problem. Most common in the unit was the heater would fail to work over time. There is 3 different components that control this function, defrost timer, defrost heaters and defrost terminator. All three have a purpose and a job, they depend on each other to complete this cycle.
Here is a link on GE and Defrost System
I hope this helps you, If you need time to complete this or what for parts, you can defrost the unit, and it can take up to 3 - 5 days to re-occur, yes the unit will do this again unit repaired correctly.
Good Luck
Aug 19, 2011 | Refrigerators
Refrigeartor not chilling, freezer not freezing
If you have built up ice inside the freezer walls, and the defrost assembly isn't functioning, this could be the problem.
Defrost the unit! Take all the food out of the freezer side, remove shelves; remove inside back panel. If there is a lot of ice build up there, then your defrost assembly is not working or your refrigerator is not a frost free unit. Defrost either by leaving the freezer door open over night or you can speed the process up with a hair dryer. Once the ice build up is dealt with, you can plug the refrigerator back in and see if it will now freeze the freezer and chill the refrigerator. If it does, and you have a defrost assembly you need to order it and have it on hand when the ice builds up again.
Jun 05, 2011 | Refrigerators
The freezer wont freeze and the back panel is covered in frost
Hi and welcome to FixYa. I am Kelly. Your refrigerator is not defrosting automatically. This can be caused by:
1. Defrost time control
2. Open defrost heating element
3. Evaporator fan motor either not running or running to slow.
4. Wiring
Since you did not include a model number and due to the various defrost controls I can not help you. I really need your make and model number to point you in the right direction or to provide you a source for replacement parts.
In the mean time you can get a 2 - 4 day reprieve by doing a manual defrost. You do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
All this will do is de-ice the evaporator coils. (I.e what the auto-defrosting function is supposed to do.) The automatic defrost circuit will most likely have to be troubleshot to return the unit to normal service.
Thanks for choosing FixYa,
Kelly
Sep 19, 2010 | Kitchen Ranges
Refregarator get defrost at the meant time, frezer working well.
The problem is most likely the defrost heater element(s) and/or the defrost timer. The defrost heater element(s) are located with the evaporator core behind the access panel inside of the freezer, and can be removed, tested with an ohm meter, (any reading other than infinity would most likely mean the heater element is functional) and replaced if necessary. The defrost timer can be located inside of the refrigerator, or outside of the refrigerator behind the front kick panel, or behind the rear access cover on the back of the refrigerator.
Usually if the evaporator core is freezing up and not allowing air to flow through the evaporator core, (necessary for the system to function properly) then the defrost timer is most likely working and the defrost heater element(s) would most likely be at fault.
Always place a towel on the bottom of the freezer and use a blow dryer to defrost the evaporator core and never use any sharp or hard objects to pick away the ice or the evaporator core can be damaged and the refrigerant will be leak from the system.
I have included some images to help assist you, and a new defrost heater element or defrost timer can be purchased from an appliance parts distributor.
Jul 17, 2010 | Amana ARB8057CSL Bottom Freezer...
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool AFB126/H/AL Freezer - Defrosting & Refrosting
Hi. I am Kelly and welcome to FixYa. Here is the real question..... Is the food staying frozen?
Freezers usually defrost 3 times a day (8 hr intervals) Some as often as 4 times a day. The freezer use concept is that it is not opened more than 3 times a day. (Yes there will be more times than that any given week)
Having said all of that.... some things to look at.
1. Check the door seal for any signs of tears... grease... collapse...
2. Make sure there are no gaps in the door or between the closed door and the seal.
3. Many people don't check this one... but make sure it is level. An un-level freezer can cause the door seal not to function correctly.
Now if your saying that the food is actually defrosting... then there are a few other things that can cause that.
A. Sticking / defective Defrost timer
B. Defrost element is not heating and the freezer goes through a VERY long defrost cycle as the contents have to reach 60 Deg F for the 60 Deg bi-metal thermostat to close and advance the defrost timer to start the compressor.
C. Intermittent operation of the 60 Deg thermostat
I hope this clears things up a bit for you.
Thanks for using FixYa.
Kelly
Feb 10, 2010 | Freezers
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
The freezer on our kenmore fridge keeps freezing up and then the fridge doesn't cool. It's a bottom freezer style. We have to unplug it and let it unfreeze in order to get it working properly again but it...
defrost problem, check defrost thermostat on evap coil by removing the back panel in freezer for continuity, if open, replace. check heater in the same fasion, if open, replace. if both are ok, replace defrost timer, or adaptive defrost control.
Jul 01, 2009 | Refrigerators
Maytag RSW2700 Freezer cold Refrigrator Warm
Check for excessive frost build up in the freezer on the back panel. This would indicate that you have a defrost problem. One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, measures open (bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Apr 11, 2009 | Maytag Freezers
PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Jan 06, 2009 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
