Question about Refrigerators
Whirlpool side by side...part 2304353 fell off the ice maker and cant figure out how to put back on
The part that fell off, hangs on the wire < shutoff arm > that is above the ice cube pan. This wil stop the ice maker from making ice when the pan is full.
Posted on Jan 22, 2011
I have slimey, flaky sediment at the bottom of my glass of ice water. The water side is clear. I have a Whirlpool refrigerator with filter at bottom of freezer side. What can I do?
Your ice maker has a type of mold in it. Dump the ice turn off the water to the ice maker and let the ice maker clear the ice in it. Then get a spray bottle, put a little laundry liquid bleach and water in it and spray the tray where the ice cubes are made. . Let it sit for 10 or so minutes.then turn back on the water and let the ice maker go thru several cycles, dump that ice and then you're good to go.
Jan 06, 2014 | Whirlpool Refrigerators
Where does part # 2304353 go whirlpool refrigerator model#ed5rhexnl03
it goes on the arm of the ice maker is what I heard
Oct 29, 2010 | Microwave Ovens
Parts inside my ice maker in the door fell out cant figure out how to get the front panel off the ice and water maker
Remove the top freezer door hinge cover and disconnect the plug there . This removes all power to the door so the refrig can still run while working on the dispensor . Use a butter knife slipped down between the lower portion of the dispensor cover and the main dispensor from the inside and press down . There are 2 plastic tabs holding the lower cover in place . After the lower portion is unclipped , lift upwards to remove the top portion . Disconnect the plug to the dispensor front . There are 3 or 4 screws holding the white " body " in place , so remove them and it should slide out a little ways to allow access to the inner workings .
Jun 08, 2010 | Estate TS25AFXK Side by Side Refrigerator
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
Hing and plug fell out and now Ice maker door stays open
It just un-snaps. Pry gently along the top or bottom edge and work it off with a plastic putty knife. Snaps pretty good and sounds like it is breaking.
Eric
Jul 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Spring and Mechanism Delay fell out of ice dispenser
This is common, take your model number and go to the appliance parts store and order a ice chute dispenser repair kit.
Dec 25, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker is not working...
It sounds like the piece that holds the little ice door in place with a pin. If this is broken the only way to fix it is with a kit that Whirlpool has released. The part number for it is 8201756 and most appliance parts stores will have it. It contains a metal bracket that replaces the tabs as well as a new door assembly and instructions on how to install it. Hope this helps!
Oct 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Jul 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
941 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
