Question about Kenmore Refrigerators
My kenmore fefrigerator not cold anymore, what should I check first pls!
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
First check the freezer compartment for signs of ice build up. If the unit is running and not cooling. If you note ice build up do the following.
1. Unplug the unit.
2. Remove the contents of the freezer compartment.
3. Place a fan blowing into the freezer compartment of about 2 hours. (Makes a water mess. Mop and rags required)
4. After 4 hours wipe the internal cabinet dry.
5. Plug in the unit and let run about 30 minutes.
6. Reload freeezer contents.
This is a manual defrosting procedure. It will only provide relief from the symptoms of no cooling for around 2 days. If the manual defrosting returns the unit back to normal temps then you will need to have the unit serviced and the automatic defrost circuit repaired.
The problem can be
1. Defrost control,
2. Defrost heater element,
3. Wiring, or
4. The defrost thermostat.
Any one of the 4 can cause the problem.
If the compressor is NOT running at all the problem can be
1. Defrost thermostat.
2. Defrost control
3. PTC start relay or the KliXon thermal overload (2 part Assy)
4. Run capaicitor
5. Compressor
6. Temp control.
You did not provide a model number in your post so all of the above are GENERIC terms. If you need specific information you will need to respond with your model number.
Thanks for choosing FixYa.
Kelly
Posted on Sep 11, 2010
Interior light blinks Kenmore fefrigerator
false contact.just unscrew the bulb and adjust again
Dec 07, 2015 | Kenmore Refrigerators
Fefrigerator side not cooling properly, around 47 degrees.!! What's up?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 27, 2011 | Microwave Ovens
Fefrigerator part not cooling model number dfbb363l serial no# 021706h0000002144
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Viking DFBB363 Bottom Freezer Refrigerator
The freezer gets too cold and the bottom doesn't get as cold anymore
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Not defrost fefrigerator too warnm
Try running a manual test of the defrost cycle
Aug 16, 2009 | Kenmore Refrigerators
Cold water will not fill in Kenmore top load washer
The problem is most likely the cold water adapter. There is a wire harness that connects to it to tell it when to turn on the water. That part is not functioning properly anymore and that is why it is humming when it tries to work. Cheap part and it can be bought at any appliance repair shop. When you take off the back panel you will see what I am talking about. I used to work for Sears as an appliance repair man and I saw this problem a lot with Kenmore washers. It's easy to fix and not very expensive. Let me know if you have any other questions.
Jan 18, 2009 | Kenmore 22422 Top Load Washer
Frig want get cold anymore
check the relay button might have to be replace it happening to me
Jan 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Water not cold anymore
the tank in the fridge may have a block so only the warm water is coming in and not cycling thru the tank to be chilled? would be my best guess
Jun 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
