Question about Refrigerators
I have a refrigeration 253-73093300 sears brand. When it defrosts we get water pouring into the refrigerator and on the floor. Where does it come from? Can you advise. Thank You, Luciano
  • luciano gonzalez Sep 13, 2010
    THANK YOU YOUR ADVISE WAS THE PROBLEM.
    LUCIANO
    Brigadier General:
  • 3,917 Answers
Hi
The defrost water is supposed to go down a drain below the evap coils.Most probably that drain is clogged.
Please check the link bellow related to your query:-
http://www.essortment.com/all/defrostfreezer_rkgt.htm
Also check this link to unclog the defrost drain pipe:-
http://www.paulstravelpictures.com/How-To-Fix-A-Leaking-Refrigerator/index.html
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 12, 2010
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
My freezer section is freezing up on the floor of the freezer and then it melts and runs out onto the floor. What could be wrong with it?
You have a clogged defrost drain line. Remove the back panel and chip the ice away pour hot water to clear the defrost drain. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have an amana abb2522feb bottom freezer refrigerator and need to access the drain pipe. How do I access this? The problem seems to be the drain line is clogged because we get a pool of water about...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Amana ARB9059CS Bottom Freezer...
Icemaker isn't working. Hot water pouring out
Most ice makers do have a defrost element below the ice maker. The problem you described is strange. I would like the model of the refrigerator and brand name. Unplug refrigerator and remove ice maker from freezer compartment now. If water continues to flow you may need the service line that feeds refrigerator turned off until I get your model number. Thanks, Sea Breeze
Feb 15, 2010 | Refrigerators
My freezer defrosted and the refrigerator is not as cold as it was
That sounds like the compressor start capacitor,relay or overload. It could even be the defrost timer or part of the defrost Adaptive Defrost Control. I will need the Sear Kenmore model number. I will need you to communicate with me and look around the door of the fresh food section for a model number. Sears uses a different model number when they sell a Maytag, Whirlpool or any Brand nam. Their number after changing would look like this 231.65489 near floor behind door seal and near kick plate.I will help you if you let me know, Thanks Sea Breeze
Nov 13, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
12 yr old ge refrigerator leaks water on kitchen floor occassiona
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
