Question about HP LaserJet 1300 Printer
Gray pages I am getting a gray "haze" over my entire printed page. I have replaced the toner twice and cleaned everything that I can reach but can't get it to go away. Is this a tone issue?
  • 300 Answers
It is a high voltage problem, normally caused by the toner cartridge, but if you've already replaced this i suggest you clean the cartridge contacts in the printer, if this doesn't work you will need a replacement HVPS (high voltage power supply)
Posted on May 17, 2008
Dirty pages
sounds like a dodgy black toner - is it a 3rd party toner - had this quite a lot myself at work with cheaper cartridges. to print a cleaning page just flick through the menu to diagnostics or print quality - in here you should find some cleaning tools of the machine
Oct 11, 2013 | HP LaserJet 5550 Printer
Using an HP LJ1320 printer. When I print my page comes out with a faint gray look to it (not white). When I duplex the gray intensifies. I thought my toner cartridge was leaking toner so I replaced the...
Your Print density could be set too high.
Try to Decrease the amount of Density through the device configuration utility.
You Must have teh HP Toolbox installed to change printer settings
Feb 15, 2011 | HP LaserJet 1320 Printer
Printer leaves a grey haze on the page.
If your fuser is not failing then someone probably didn't install the toner properly. Regardless, it is incredibly hard to clean toner out from all the guts and the gray won't go away as long as it is there. I would take it outside, wear a smock, and blow it out with an air compressor or half a dozen cans of compressed air. Wipe down and clean every part you can.
Replace the toner cartridge. Then run a couple dozen copies of something to pick up the remaining toner from the internal mechanisms. See if their is any more toner. If there isn't...then somebody messed up and you just need to work the last of the toner out of the innards.If there is more toner after you clean it out and replace the toner cartridge, start thinking about replacing the fuser.
Oct 02, 2009 | Dell 3000cn Laser Printer
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Grey band on left side of printed page.
replace toner drum or replace cartridge
Mar 19, 2008 | HP LaserJet 4 plus Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
Brother MFC-8500 prints solid gray pages
I have seen the Toner cartridge in these cause this and also thought it was drum but new toner actually fixes it, have you installed new gen toner as well as drum? Make sure you tell machine you have fitted new drum too,
Sep 08, 2007 | Brother MFC 8500 All-In-One Laser Printer
HP LaserJet 1300 Printer Logo
290 people viewed this question
Seeker5211
Seeker5211
