Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My r520c-t7 water pump cut out last night and now i have no water . need to know how i might be able to get it running again?
Installed correctly last night, do not have even a drop of water at the Fawcett. 40 psi on tank
First check the faucet strainer, right on the faucet. Then make sure the cut-off under the sink is on. Faucet strainers stop up easy.
Jun 30, 2015 | Plumbing
I have a 95 Cadillac deville 4.9 just replaced water pump, serpentine belt, thermostat, battery, and radiator. Now when driving the car at night it will just cut off. It did this last night multiple times...
If it quits and starts back up, its going to be tough to diagnose.
It needs to happen on demand to track down the problem, otherwise you may never find it and know its fixed.
Could be the key switch, a relay, an ignition component, or something else electrical.
Mar 27, 2015 | Cadillac Cars & Trucks
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
My 93 camry start in all but i have new cap,wires,and plugs it runs but when im at a stop light it fell like its go cut off so i have to hit the gas so it want cut off what is it? Theres no lights on so i...
Always try the cheapest most likely thing first you could just have gotten bad fuel if the last time you filled up it had rained you might have water in fuel so get a can of HEAT and add it to your Gas then run it for a while 20 minutes then let it sit over night and try it again to see if thats what is going on it could be that simple!
Jun 10, 2014 | Cars & Trucks
Water not pumping
the pump is plugged possibly, remove the hose from the drain at the sink and using a garden hose, back flush it and it might spark it back to life. help me help others, if this is what fixed you up, please tell me or tell me what you found was the problem. thanx Jay the pool pump motor repair guy longwood florida
Nov 17, 2013 | Asko D1716 Built-in Dishwasher
Twice in the last year, the floater of my toilet jammed causing the water to run all night long. After running for 12 hours the water kept running but turned brown and muddy. After a day or so, all returns...
the valve that controls water flow is sticking. replace the interior water stand pipe valve with a new one you got dirt in the valve and it is not clsoeing. It would be a good ideal to put a filter on the output side of the pump. Aslo the wll level is most likely low due to lack of rain causeing the brown water. If you need more help post and let me know. the Vlave assembly costs $15.00 for a good replacement. also check that the flush handle is notr cathcing on anything and the flapper valve does not have a hole or rust arounf the ring.
Sep 28, 2009 | Little Giant Pumps W8G-X Submersible Deep...
My saltwater pump will not come on at all. It ran a full 12 hour cycle last night. Any suggestions?
After you run it for a cycle, the chlorinater will automatically come on at the same time the next day. If you want to run it before then, you need to turn it off and back on again to reset it. You may even have to unplug it and plug it back in. Good luck!
Jun 18, 2009 | Intex Automatic Salt Water System for ...
1995 Toyota Avalon started overheating so I had the thermostat
sounds like you will need to check and replace a leaking cylinder head gasket
Jun 06, 2009 | 1995 Toyota Avalon
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
73 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
