Question about Radio Shack Pro-96 Scanner
My innova 3130 obd2 scanner does not turn on. I replaced the batteries and looks like it is going to turn on, the blue backlight comes on, and then it get innoperable from any keypad. The display never comes on. Any way to fix this device?
My buddy's 3130 did this same thing today. Here's how I fixed it.
While turned on (back light is lit), unscrew the top two screws on the back and remove them.
With the back of the unit facing your palm, tap the unit against your hand like you are trying to knock the screws out of the holes.
After a few taps, the screen should come back on.
Hope this helps. It worked for us.
Posted on Sep 15, 2010
  • mohamjordan Dec 30, 2010
    My 3130 did the same thing. Screen back light flashes on then off and will not power on. I removed all screws and opened it a part and just played with it then don't know what it just works again. After uknown times of functioning properly it will stop working a gain and i have to do the above all over. peace of **** unit
Doesnt connect to pc
with Innova Equus 3130 live data software loaded to the pc
it needs the correct input cable
should work..... just push the right buttons on the scanner
https://www.youtube.com/watch?v=bEkQvg55ZYs
May 19, 2016 | Innova Equus 3130 Diagnostic Code Scanner
How do i reset my innova 3100 scanner
if its a firts generation look behind of the battery tab. there is a reset hole that you must push with a pperclip
Oct 15, 2014 | Innova 3100 OBD II Code Reader
Why won't my Innova 3130 Scan Tool work on my 2000 4runner???? Neither cord plugs into the diagnostics box. Please help!!! What am I doing wrong?
DTC terminals vary and you may need a suitable connection to plug in. Some scanner units come with up to 10 extra leads to compensate for manufacturer's whims.
Jul 22, 2014 | Cars & Trucks
Why does my innova 3100 obd2 scan gives err message on obd2 certified car ?
Because it is likely not up to date on CAN BUS technology, an uprade is suggested.
May 27, 2014 | 2006 Chrysler 300
The check engine light will not go off and not one shop can find anything wrong with the car.
Reset your ecm. Do this by turning your key to on position with a/c on " engine not running" then disconnect positive battery terminal wait 30 sec. and reconnect, Should clear out all codes from ecm. If this don't work may have to go put on the computer to diagnose problem. But i think this will help. Good luck and let me know how it go's.
Mar 23, 2011 | 2000 Aston Martin DB9
ABS light just came on, is it an easy fix. My abs warning light comes on often. It usually stays on until I restart the car, then it might stay off for days but will always relight. Often, I turn the...
The code scanner that you need is called ODBII code reader with ABS, and it works in the same way as the one that you connect to the car computer module (ECU) to read codes when the check engine light comes on, but the cheap ones that you can buy from $50 do not have the ABS brake scan function.
If the problem is the ABS, then it is often a wiring to abs problem, or a defective ABS control module, a scan reading is necessary to know what the problem is.
Below few examples of Code reader with ABS:
Equus 3150 Innova ABS + Professional CanOBD2 ...
$199.00 - Amazon.com
Cp9449 Brake Scan Abs Diagnostic Tool Obd2 ...
$219.67 - eBay
Equus 3160 Innova ABS + Professional CanOBD2 ... $259.99 - Amazon.com
CAN OBDII Code Reader with Multilingual Menu $49.99 - Harbor Freight Tools
Mar 24, 2009 | 2001 Chevrolet Blazer
Radio Shack Pro-96 Scanner Logo
583 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
