Has anyone heard of problems with mitsubishi wd65838 and directv hd receivers using HDMI cables and having audio problems? I've tried 3 different tvs 3 different HDMI cables and 3 different satellite receivers. There is an issue here somewhere.
  • Patrick McAlexander Sep 13, 2010
    Its only on the audio on the HDMI inputs.
  • 5,138 Answers
Are you having Problem with the TVs audio inputs? What?
Posted on Sep 11, 2010
  • ladywinn
    ladywinn Sep 15, 2010
    What is your Model number printed on back of TV?
My daughter spilled water on Motorola cable receiver i unplugged it for a day and now it has a code ber1 how do i fix it
The Motorola HD-DVRs are notorious for having problems when connected to a receiver. This is because your HD-DVR has anti-piracy code in it that sometimes detects your receiver as an unauthorized recording device and then will not allow anything to be sent to it for fear of piracy. But in your case, you are getting video and audio to your receiver without an error message.
You might have a faulty HDMI cable. If you can borrow one or have another one on hand try using a different one to see if anything improves.
If that doesn't do anything you might need to goto monoprice.com and buy one of their HDMI v1.3 switchers so you can run HDMI from your cable box and from your sound system receiver to the switcher, and then one HDMI cable to your HDTV. And then run a digital optical audio cable from your cable box to your receiver for audio.
The switchers aren't very expensive and should fix your problem (if it isn't a faulty HDMI cable). If the problem persists even with a switcher I'd say your HD-DVR is malfunctioning. And since you said your DVR sometimes is unaccessible, I'm leaning towards a bad HD-DVR as part of the problem.
To troubleshoot I'd try these steps (in order):
1) Try a different HDMI cable from your cable box to your receiver
2) Trade your HD-DVR into Comcast for a new one and see if the problem persists.
3) Buy the HDMI switcher from monoprice.com (make sure it is v1.3)
If all that fails, personally, I'd say you need someone to look at that!
Aug 13, 2014 | Cell Phones
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
Video drop
Try to isolate the offender. Start with one device and see if the problem remains. After a period of use, add in another component and see if the problems reoccurs. Once it does take out that unit and add in others, in the same manner, to see if others cause problems or the number of devices is an issue.
Jan 07, 2014 | Denon Audio Players & Recorders
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
