Question about Canon PIXMA MP600 all-In-One InkJet Printer
My Canon MP600 is running an error code 6A00. The lights on the panel are flashing and none of the buttons are functioning.
  • 10,515 Answers
This error code indicates a jam. The most common jam is a paper jam, which you can fix yourself by removing the cover and examining the internals for any stuck pieces of paper. They may be small from being torn and jammed through the machine, however it is likely there is one there. Your manual may give information on how to automatically clear a jam, however this does not always work. If you see any pieces of paper in the machine you will want to remove them and try again.
Also, There seems to be a considerable number of people who have encountered this error code on various Canon printers. Below is a forum you may want to read.
http://www.fixyourownprinter.com/forums/inkjet/37440
From what I am gathering from the forum is that this is a mechanical error of some sort with the prime culprit being the print head / slider mechanism. I hope this printer is still under warranty as it may require service.
Below is a post from one of the forum participants who also have a MP500 and got the same error code:
"I have a Canon Pixma MP500 and I got the 6A00 error. When I moved the cartridges to the left that white thing attached to the spring underneath was stuck. I just pushed it toward the back of the printer and cleaned underneath it....LOTS of ink. It works great now. Canon should mention this in their manual and have it as one of the maintenance options that you can do. But hey of this was the case then they wouldn't make their $60 to fix the problem. A CAVEMAN CAN DO IT! Lol."
Note - If the problem persists, that would confirm a hardware failure and needs you to contact Canon for repair / replacement options.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Error code 6A00
I HAVE A CANON MP600 ALL IN ONE PRINTER. SCANNER etc., AND I HAVE AN ERROR CODE OF 6A00 COME UP! both green and amber lights flashing and will not allow me to print... can you please help
Aug 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00 green and yellow lights are flashing. Printer will not print.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer error code 6A00
Heello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Nov 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 error code U043
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
How do I solve error message 6A00 on canon printer?
Turn switched it off, open the lid and manually slid the cartridge-tray to the left. Use a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
Please let me know.
Sep 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Feb 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
