Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer is being heated but only for a certain amount of time. We set the time at 65 minutes, but it quickly drops to 30 within the time span of 10 minutes, and this causes the dryer to cool down.
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Intermittant Heat on Gas Dryer
Check the venting tube. It maybe clogged full of lint somewhere inside of it. If so the moister contro sensor will shut off the burner within due time such as yours
May 01, 2010 | Maytag SDG4606A Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Rapid cycling
The has been no solution offered, just as there was no solution for the individual who had a similar problem and posted in Nov 2006. The only offer is to purchase a solution which I have determined is the only function of this website!
Apr 01, 2008 | Comfort-Aire HD-651 Dehumidifier
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
