Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Please help! First power on, when boot up, my Dell 5150 goes directly to "Start Windows Normally" screen selection. Sometimes when boot up, screen goes to a blue with "A problem has been detected and windows has been shut down to prevent damage to your computer". Selections: 1) If I select "Safe Mode" or "Safe Mode with Command Prompt" - then shows a list of files and goes to a blue screen with a "?" in upper left corner. Power needs to be unplugged from computer to shut off. 2) If I select "F2" during boot up, I can see selections. I'm not sure what selections should be so I let it alone without making changes. 3) If I select "F12" during boot up, If I select "Hard Drive Diagnostics" looks like the hard drive is being checked. Says: Drive 0: ST3808110AS - Pass 4) If I select "F12" during boot up, If I select check system looks like it's The only drive that responds to a disk is A: drive. All others do not respond. Did I pickup a virus? Please Help. Thanks.
    Scholar:
  • 181 Answers
Main cause of the problem is a corrupted operating system which can be cause by a virus or a defective hard disk or a defective memory module. First to try is to replace your memory with a certified good one. If the problem persists, Try to reinstall you windows using your CDRom. If there still the problem, replace hard disk.
Posted on Sep 13, 2010
My laptop has been freezing for a while now, I've been getting a black screen with a blue bar across the bottom of the screen where the taskbar should be. Sometimes it boots up and makes me go into...
If you have Windows Installation disk, use to repair Windows.
First go inside BIOS(Setup) with Del or F2 and change under boot options for CD/DVD to boot up first before HDD.
Put the CD in, boot from it and select repair windows once it comes up
Jul 19, 2010 | Toshiba Computers & Internet
Dimension 5150 computer wont boot up -flashing amber light
While the system begins booting --before the xp logo shows, if it gets that far for you, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The OS will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to format the drive and reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 22, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell wont display welcome screen after boot for 15 min.
You must have turned off the Welcome screen. go into Dell help and search for Welcome and have it "Default".
Aug 24, 2009 | Computers & Internet
Dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Jul 09, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
I have a dell inspiron 5150 and it won't start up it started with NTLDR is missing I tried to replace these files with new ones didn't work. I have 2 laptop another one is a compaq armada 1750 now the 2...
inset the extrnal dvd drive attch with usb cable and insert the orignal windows cd dell recover cd and boot timepress F12 and select the extrnal drive and start your system setup.............ok
Apr 02, 2009 | Dell Inspiron 5150 Notebook
Dell dimension5150 won't startup
The solution is to restore the GDI32.dll from the service pack into Windows system folder with the following steps:
  1. Boot from your Windows CD
  2. At Welcome to Setup screen, press “R” to start repair option and open up a Recovery Console’s command prompt window.
  3. Select the Windows installation to use, normally is C:\Windows and just one option. If so, press “1′ and hit Enter.
  4. If prompted for administrator password, enter the password (normally blank) and hit Enter.
  5. Make a backup of existing GDI32.dll in system folder with following command: REN C:\Windows\System32\GDI32.dll C:\Windows\System32\GDI32.dll.orig (take note of spaces)
  6. Replace “C” of the drive letter of your Windows installation drive if necessary.
  7. Then copy backup GDI32.dll from c:\windows\servicepackfiles\i386\gdi32.dll to the system folder with the following commands: copy C:\Windows\ServicePackFiles\i386\GDI32.dll C:\Windows\System32\GDI32.dll (take note of spaces)
  8. Restart computer.
This should Fix the problem.
Oct 08, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 fails to boot
you might have deleted/corrupted some of your boot files so you might want to restore your default to be able to retrieve your old booth. then try fixing it from there.
Jan 10, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Error - The Hard Disk Was Not Found
Boot into the BIOS, I think you hit the Delete key on Dell's to get into the BIOS, but I'm not sure. You should see some type of message at boot that says "To enter setup press XXX" Where XXX is the Delete key or some other key.
Once you're in the BIOS setup see if your HDD is listed. You may also find the option to reset the BIOS to default. Generally speaking this will not hurt anything and may be worth a try.
Dec 19, 2007 | Dell Precision M60 Notebook
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
