Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
The problem is that i bought a computer today, when i plug it in, in my SyncMaster 930B (samsung) this is what happens: White small windows in the left top corner start blinking. One saying "Digital" the other "Analog". If it stops in "Digital" it says there is no signal. If it stops in "Analog" the screen turns black and the power light blinks. Do I have to replace the monitor?
3 Suggested Answers
  • 11 Answers
SOURCE: moniter keeps blinking analog and digital at the
This happens when your monitor cannot detect a VGA or Digital port, either on the monitor it self or at the video card. If you don't hook it up to anything at all and turn it on it will do this.
Step #1
First make sure that you have the cables properly connected to the monitor and to the video card using either a VGA port (blue one) or the Digital port (grey or white one). If this doesn't fix it move on to step #2.
Step #2
Try troubleshooting your video card by hooking up another monitor (if available) and see if it too is inactive. If you test with a proven functional monitor and it wont activate then you are most likely looking at a faulty video card. If your test monitor works, you may be looking at either a faulty cable or a faulty brand new monitor (it happens).
**Note: craigslist.org in the "free stuff" section is a great place to find free CRT monitors for free if you don't have one to use yourself.**
Also try to hook up your Samsung monitor to another PC (if available) to see if you get different results. If you do that and it works, that is a sign that you have a faulty video card in the first PC.
**Note: Depending on how you are trying to use your monitor (PC's only monitor, or as a secondary monitor for a PC or laptop) you may need to make sure that in your display settings you have the box checked that says "extend my windows desktop to this monitor" (Windows XP). If you are intending to use it as a secondary you will need to have this box checked or it wont be recognized.**
If you determine that the most likely cause is that your monitor or cable supplied are faulty, Samsung or your retailer should help you get a replacement. Both will ask you to verify the results of steps 1 and 2 before honoring a warranty.
I hope that this information helps. If it doesn't, post back with more information and I will try to help you find a viable solution
Good Luck!
Posted on Jul 28, 2009
oldrogers
  • 53 Answers
SOURCE: Syncmaster 910t blinks image perfectly once and goes back to black
I've had same problem and I fixed it!
With good CCFLs, clean supplying voltages, all good capacitors and resoldered junctions, the backlight still turns on for fraction of second and goes off.
It is in the Power Supply / Inverter board. In the Inverter part there are two dual n/p-MOSFETS U3 and U4 (models STS7C4F30L, SO-8 packages). I've found they both have too high ON-Resistance (perhaps due to age and constant overheating). All you need to do is to replace them. I've checked many models and found closest by Rds and IDcont (continuous drain current) are IRF7389, you can find distributor by findchips.com, but I've bought them at newark.com, they're cheap.
The hardest thing was to unsolder old chips, they are glued to PCB and because of overheated material under them, the copper could easily go apart. Therefore, the best is using fine tips cutters, cut off all legs one by one and then take chip body off the PCB and take legs from pads by iron. That's all you need. After that my monitor started working as new even with old CCFLs. Good Luck!
Posted on Sep 09, 2009
How do I replace the inverter in a samsung syncmaster 930B?
The 930B and the 710T use the same power supply/inverter boards. Below is a link to a repair guide for the 710T unit that should get you going in the right direction.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/
Jan 27, 2013 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a power light on my Samsung syncmaster 930b but no image at all is this just a lamp issue or is it a dead moniter.
The problem can be bad caps in the power supply, inverter circuits, or bad lamps. You need to open it up and see, report back what you find so we can help you further, see example of failed monitors due to bad caps, lamps here: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor will not turn on and the green light just flashes
There's an internal hardware electronic part/s of your samsung syncmaster 930 that is cold soldered / defective. I suggest to bring the unit to an authorized service center to fix the problem. regards
May 29, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
91 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
