Question about Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator
Front panel just beeps. No button works except on off butten. Ice and water button not are not lite
    President:
  • 1,796 Answers
HI!!
Note: If dispenser is active for more than five minutes, an automatic lock out sensor will shut down power to dispenser area. See Dispenser Lock/Unlock for unlocking information.
The Dispenser Lock/Unlock affects all keypad functions.
To Lock Dispenser: • Press and hold the Lock/Unlock button for three seconds. A green indicator light above the button will illuminate when the dispenser is locked.
To Unlock Dispenser: • Hold the Lock/Unlock button for three seconds. The green indicator light above will go out.
To Dispense Ice and Water: • Select Water or Cube ice mode by pushing button on dispenser control panel. A green light above button indicates mode selection. • Press container against dispenser paddle. When dispensing ice, hold container as close to chute as possible to reduce spraying.
Posted on Sep 12, 2010
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Control panel failure
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
Apr 13, 2014 | Refrigerators
I have a ge profile refrigerator and it works fen except it ekes buzzing. The ice lock/lock function, no body is pressing the button but it keeps locking and unlocking itself and the buzzing/beeping i
The switch that does the lock/unlock has got wet inside.
Make sure you can see the back panel of the switch and use a hair dryer to warm the panel back and the front of the switch. When it gets warmer it may dry out and start working normally.
Dec 21, 2013 | GE Refrigerators
I have a kenmore elite side by side. It is about 2-3 years old. When I press the ice/water crushed or cubed buttons the system double beeps (I.e it beeps 2 times). It won't do anything except beep. I don't...
If the child lock is set it will do this. If you try to turn it off and it doesn't work, the control panel will need to be replaced. Is this your problem?
Thanks, Repairman45
Dec 22, 2010 | Refrigerators
The controls on the front of the refrigertor do not work. You push water or ice and they just beep at you and you cannot dispense. All the other button beep too and you cannot change them. There is no lock...
If you would like me to assist you I can but will need the model number to help you locate the problem.Sounds like either the dispenser control board, keyboard or low voltage supply to the dispenser has been affected. Sea Breeze
Dec 16, 2009 | Maytag Refrigerators
LG refrigerator LSC27950st touch panel
LSC27950ST Ice dispenser works fine, unable to dispense ice cubes or crushed. motor works great with no load. just doesn't seem to have enough power.
Apr 01, 2009 | LG LSC27950 Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MFI2266AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
452 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
