Question about Singer Sewing Machines
I have an old Featherweight Singer which threads backwards. When I replaced the needle, and threaded the machine, every time it unthreaded after a few seconds sewing. We tried threading the other way as well - and had the same problem. Then it appeared that the thread was breaking off. What have I done wrong?!
    Genius:
  • 1,788 Answers
Look at your model number on your machine, then go to singerco.com and you can download a copy of your manual, usually, for free. You could also call the customer service number at 1-800-4singer
Posted on Sep 11, 2010
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
The top needle unthreads after just a few stiches. I have a Singer 2950 and am new to sewing.
Are you saying that the thread is breaking?
CAUSES of upper thread breaking
needle is in backwards
improperly threaded
tension to tight
needle bent or blunt
thread to coarse for size of needle
needle too long for machine
burr on needle
tension discs worn so that thread works in grove
neele too fine for size of thread and fabric
lint or dirt around bobbin case holder
irregular sewing speed
AND THE BIGGEST PROBLEM IS:
threads not properly pulled back under pressure foot when starting to sew
This means, Have enough of the upper and lower thread pulled to the back and hold for the first 2-3 stiches,
Do this every time and it will become second nature and you will do it automatically
Aug 28, 2009 | Singer 2950 Mechanical Sewing Machine
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Threading diagram for a 1941 Featherweight by singer My repairman sewed just great when I got it home it breaks threads all the time. I assume I am threading it wrong.
This machine threads from right to left in the needle and the flat side should be inserted to the left.Try this and let me know how it works.
sewman7
Apr 30, 2009 | Singer Featherweight II 117
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
My thread often becomes unthreaded from the part that raises and lowers the needle causing the thread and fabric to jam up
Your needle should not come unthreaded in the middle of sewing.. if it does, it is because the thread breaks. this can be a simple tension problem or brittle thread.
if you are talking about at the beginning of sewing that the needle comes unthreaded, then you should just pull out 6-8 inches of thread through the needle before putting your fabric under and begin sewing.
i hop that helps.
Apr 16, 2008 | Singer Featherweight 132Q Mechanical...
Singer sewing machine
If you are using a threadcutter on the Left side of the machine, it may not leave enough slack when you go to start a new stitch, and as the needle decends, the thread is pulled through the eye.
Just try to pull a little more thread through before you recommence.......just why manufacturers would locate a threadcutter where it will not quite allow enough slack thread for the needle to move down for the next stitch without unthreading the needle is one of life's great imponderables.
Bargainbox
Jan 18, 2008 | Singer Featherweight II 117
Sewing Machines Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
