Question about Yamaha Boating
What are the carb settings on a 2001 yamaha gp1200r?
Yamaha torque specs
The owners manual does not provide torque specs there is an on-line manual for $5 which claims to cover torque specs at: https://www.tradebit.com/filedetail.php/141315359-yamaha-waverunner-gp1200r-service-manual-repair-2000-2002
Jul 05, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
How to set carb on yamaha r1
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/330287-98-r1-carb-adjustment.html
R1 Carbs lots of pics Page 53 Engine
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 27, 2012 | 2001 Yamaha YZF-R1
I just rebuilt my carburetor to my 2001 Yamaha yzf r1 and I need to adjust the carburetor needles about how many turns do I need to do starting from the left side of my carburetor?
Hi, Tazz for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/4-mechanical-help/41018-carb-settings-2001-r1.html
Pilot Air Fuel Screw Adjustment Explained
Aug 13, 2012 | 2001 Yamaha YZF-R1
Whats float level set to
Carb Jetting Star 1100 Wiki Knowledge Base
Adjust Float level Maxair Predator Pro Yamaha Star 1100
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jul 31, 2012 | 2001 Yamaha V Star 1100 Classic
2001 yamaha r1 carbs
Hi, Khourimitche and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/300120-carb-overflowing-gas.html
Carbs leaking Here is how to fix it
Jun 21, 2012 | 2001 Yamaha YZF-R1
Was riding my 2001 yamaha blaster and in was always bogging down and stalling cleaned carb twice every nook an cranny got it started still dies out and then when it died this tim it wont start and it has...
Hello, try to switch the petcocok into reserve mode. Mine TW has pretty soon problem with level of fuel in tank.I think the reserve level is set too high.
Mar 11, 2012 | 2001 Yamaha TW 200
2001 yamaha breeze wont stay running
i had the same issue. it's gonna be a blockage in one of the vent tubes to the carb. check the line to the left of the carb that runs next to the gas tank. if thats fine then check the gas cap line. then if thats all good then check the line that runs below the carb. these are all vent tubes and allow the carb. to refill with fuel
May 19, 2010 | 2001 Yamaha DT 125 R
My yamaha gp1200r jetski wont statr sometimes
I have found that the yamahas kill switch is often the problem
Aug 03, 2009 | Yamaha 12V Air Pump
2001 raptor cabs not getting gas
MAke sure your tank vent is clear.If so you need to pull the carbs and clean the passages and jets.You may have a stuck float or needle
Feb 08, 2009 | 2003 Yamaha WR 450 F
Boating Logo
104 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
