Question about Refrigerators
I NEED TO KNOW WHERE TO FIND THE WATER FILTER FOR THE GE REFRIDGERTOR MODEL GSS22JEPHWW
  • 101 Answers
Right rear fresh food top
Posted on Sep 12, 2010
WATER FILTER HOLDER CLOG NO WATER GOING INTO THE FILTER
What is the model number of your refrigerator? There are many GE Refrigerators I need to know what we are working with
APPLIANCE 911
Nov 17, 2015 | GE Refrigerators
Does GE frig model # GSS25JETA have a water filter?
I don't see a filter listed in the parts breakdown for that model. If you had one, in would located in the fresh food section, top right rear corner. GE does have an external filter that can be installed in the 1/4 inch water line. and should last 6 months to a year depending on how much water you use and how bad you water actually is. GE part number is GXRTDR.
Mar 04, 2015 | GE Refrigerators
I have a 16 year old refridgertor tappan model side by side ice maker works some times no water in it right now how do I reset the ice maker. I guess that what is wrong with it. Thanks
Your unit has likely a filter inline and this may be clogged with an accumulation of calcium after long use.
Your owners guide should tell you where it is located.
Sep 19, 2014 | Refrigerators
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Stoped cooling in freezer and refridgertor but lights are on . ge model psw26lsrdss
check the compressor and make sure it is running,if quite warm,replace the rtc overload on the side of the compressor first,this should solve your cooling problems,if there have been outages or surges, then you may need to replace the motherboard electronics in the lower rear of the unit,but with no cooling the first approach is much less expensive
Jan 25, 2010 | GE Refrigerators
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My side by side refridgertor is freezing
Depending on model you have a condensate drain pluged up. Unplug and look on the frezzer side bottom and see how to take off the back panel. Possibely 4 to 6 screws. Once you take that off look at the very bottom. You will see a hole and some metal or foil around that hole. this may or may not have ice in it or not. If you have ice in it you can pour hot water on it from the tap. Ice gone, you can get a steamer and put the attachement that has a small end on it and blow steam down the hole. If you dont have a steamer you can carefully pour hot water down the hole and see if it is pluged. Should drain in a few min. Dont pour then 2 cups of water down the drain. You will fill up the condesate pan and have a water mess. Good luck and keep me posted.
Mar 14, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
